I finally got some good sun to test this Taiwanese MPPT I purchased recently.
http://s1259.photobucket.com/albums/ii548/pcm3012/ <---photobucket album
I had great hopes that it would get better than unity-gain current, but it seems to perform like a PWM, even though it clearly isn't. It's able to transform 24V into 12, but at exactly the same output as if 12V. I've checked the input on a CRO, and it appears to scan for peak power. You can see the input scan between 25-32V (mostly 28.5V), and also see little glitches at 26us intervals. There is very little heat coming from the heat-sink at 15A.
The ammeter is on the output of the MPPT, on a Y splitter, with circuit breakers, and I can switch it quickly back to direct panel input. The test, showing lots of ammeters at 15A, is the result of 3 tests. To obtain 24V input, I went onto my roof with a soldering iron.
Row 1: 12V input, direct from panels, followed by 12V through the MPPT
Row 2: 24V into MPPT
Row 3: 12V input re-test, then 12V into MPPT.
It doesn't really matter which is which, because it's all the same.
