I have an array with 250.5 Input Volts
  • bradadad
    • May 2018
    • 4
    The VOC is 41.75V each panel. I want 6 460w panels. The input should be 250.5 volts. It's awkward since I see a lot of controllers using 250v max input. Is my calculation wrong. is there a controller just over 250 V input or maybe I can do a series parallel? I have a 100' to reach the controller and batteries so I have been also trying to stay with the 10awg wire capabilities. The batteries are 48v.
    EDIT: I'm considering an oversized controller 48V 140A MPPT Solar Charge Controller with Max.PV Input 500V. It states to have an optimal input voltage of 280v which seems very close to my 250.5. I'm sure there's a way to split the array in two but it starts to seem complicated for me at that point and there's the extra wires.
    • 15153
    Usually there is a voltage drop which should reduce that 250.5 volts coming into the controller,
    Have you measured the voltage the panels are generating or are you just using the panel rating x 6 to get that value?
      • 15003
      Depending on operating cell temps. as f(ambient conditions) the panel voltages might be higher than the Voc.
