Equipment assistance for off grid mini home
  • Donvanhugenstein
    • Jul 2024
    I have a very small mini home that's off grid currently ran by a 3200watt inverted generator.
    I want to start with a small battery storage and it'll still be mainly ran off the generator but once the system is setup very quickly transition to solar with the generator as a backup only.
    Where I'm stuck is Im new and need the equipment.
    I want it to be outside in an external enclosure but close to the mini home, it'll just be plugged into the L14-30 (I can get that part done)
    Victron has caught my eye with their charger/inverters. It allows me to remain at 12v with my storage with their 3k or 5k system. Do I need a Mppt charge controller with these? It seems like they already handle solar charge controll being a charger/inverter??
    3k should be enough for me I think but I'll probably go 5k.
    What about the Fronius systems those also look like they'd suit my needs? I just learned about the Fronius ones today but I'm unsure if those would work with 12v.
    The place is like 15x15ft and very minimal not even a furnace, all 120v and really my only constant is my fridge at 600kwh (I plan to get a much more efficient one)
    The water pump and hot water tank are on their own breakers and thats it. 5 led lights.
    Don't need 16 batteries in series parallel and 48v system nothing crazy.
  • Rade
    • Aug 2023
    • 145
    Have you looked at the EcoFlow battery solutions? Pretty much plug and play and essentially designed for either camping or small, off-grid environments? Prior to us going solar here, we invested in an EcoFlow battery system for emergency power. We have the battery/inverter, secondary battery and a solar panel for recharging. I only had to use them once or twice.
    On that rig, we have a wood shed that we are having renovated, and given the distance from the house to that structure, I will be using the EcoFlow rig for rudimentary powering once that structure is repaired.
    Rade Radosevich-Slay
    Tiverton, RI
