Safety mechanism for power outage use of solar.
    • 5208
    #31
    I would like to see your construct of a Faraday Cage. Those are about the
    same as the shielded rooms we used at work. It that case a double shield
    was used. Here 2 sheds are metal (Morton) with multiple grounds (no bottom
    cover), house has a metal roof with multiple ground cables running down. Not
    super secure, the idea was to protect against lightning.
    Bruce Roe
    • blackft
      • Nov 2023
      • 5
      #32
      I've seen a few plans for making faraday cages. The one I like the most is a metal garbage can and lid where you start with putting an FM radio in and if it still plays when you close the lid, you have to start looking for leaks via a lantern inside and using metal conducting tape everywhere the light gets out. Continue until the FM radio no longer plays. Then put a cell phone in and see if you receive text or calls. Then line the whole thing with cardboard and stack your sensitive items within. Will it work? Wait for an EMP and let me know. I wonder how the military hardens their equipment.
        • 5208
        #33
        I would not use a cell phone. These adjust their rf power to compensate
        for loss of signal. FM has the problem, the volume has nothing to do
        with received signal strength. Unlike AM, it either works or it does not.
        It would be good to know what the frequency spectrum of the pulse
        is, and which parts are most likely to cause damage. Then concentrate
        on them. Bruce Roe
