Hi, this site is an invaluable resource and I thank all the contributors for their expertise. I've been trying to clarify a question about grid tie back-feed (Enphase iq8 inverters, poco is PGE), and I've found some excellent posts by Mike90250, bcroe, SolTex and others
As I understand it, grid tie inverters that are connected to the house main-panel will supply any house loads before exporting excess energy to the grid, and will "draw energy from the grid if the inverters aren't outputting enough to cover the loads". The last quoted part - if I'm even stating it correctly - is what my question is about:
If my inverters are outputting 3kw, my house load is 0.5kwh, and my air conditioner (4kwh load) suddenly kicks on... assuming the total house load is now 4.5kwh... is the inverter smart enough to only take 1.5kw from the grid or does it shut down completely (i.e. not output anything), causing the entire 4.5kw to come from the grid? I *think* it is smart enough to draw 1.5kw, but I'm just looking for clarification or an explanation if I'm wrong.
