Ground mount vs Roof mount?
    • 15005
    #61
    Originally posted by littleharbor2
    BoS stands for Balance of SYSTEM cost,.ie; all wiring, breakers, nuts and bolts etc.
    Like Vinney wrote, it has many meanings. The way I learned it from my days of peddling process equipment and systems before switching to engineering was that it referred to equipment and services that were needed to operate a system that were not part necessarily described in the actual quote such as nuts, bolts wires, small accessories, startup incidentals, manuals etc. and stuff which, if added to a detailed quotation for the work would make it long and probably unwieldy.
      • 5208
      #62
      The PN2000 Plug-in Kilowatt Electricity Usage Monitor appears to
      be an upograde from the KILL-A-WATT. Competition.
      1000 BTU/hour = 0.293071 KW, so generating 6000 BTU/hour with
      your old style electric resistance space heater would require 1.76 KW.
      With a Coefficient Of Performance of 4, your mini split would only
      require 440 watts! The mini COP will decrease with colder weather,
      but it will almost always be a lot better than 1 for your old space heater.
      My minis were picked in part for their outside below zero performance.
      Almost all the electric energy used by a mini split comes out on the hot
      side. That to your benefit when heating. But it will not help when doing
      air conditioning, so the COP might drop from 4 to 3. Normally the fossil
      fuel energy unit costs less than an electric unit of that energy, but the
      COP brings it back into competition. Moreso if you generate it yourself
      with solar.
      If you managed to run on 8KWh a day not including your mini splits,
      you are doing very well. I barely managed 10, trying very hard.
      It appears you are doing very well in controling energy use. But your
      property is difficult for erecting effective solar panels. Is north at the
      top of the picture? Yes I have an acre mostly dedicated to solar panels,
      cannot be seen from a house or road. Perhaps you will not be able to
      generate all your energy that way. Bruce Roe
      • vnatale
        • Jun 2016
        • 60
        #63
        After being missing in action for the last 19 1/2 months ... I am back here!
        In the intervening time I had to take care of other matters.
        Monday, I went back at solar and four days in have had much interaction with many different vendors, with many of them already providing me quotes. Soon, I will reread all that in this topic and then update all that is relevant to my situation.
        Thanks for all the assistance you have given in the past and looking forward to more of it in the future.
        • vnatale
          • Jun 2016
          • 60
          #64
          I have quotes from all vendors but one. Should have that one by next week. I've created an Excel worksheet which compares all the quotes I currently have received. Are all you wonderful people who previously participated in this topic still here? I'm ready to supply all my updated information. And, of course, have many more questions.
