Ground mount vs Roof mount?
  • vnatale
    • Jun 2016
    • 60
    This book that came out last month seems far more appropriate for reading in January 2023?
    DIY SOLAR POWER FOR BEGINNERS: Your Step-By-Step Guide To Design, Install, And Maintain Your Solar Energy System In Complete Autonomy To Drastically Reduce Your Electricity Bills. Kindle Edition
    Amazon.com: DIY SOLAR POWER FOR BEGINNERS: Your Step-By-Step Guide To Design, Install, And Maintain Your Solar Energy System In Complete Autonomy To Drastically Reduce Your Electricity Bills. eBook : Dellinger , Sean : Books
      • 15005
      1.) I'm assuming you're in the U.S, or at least North America. If the U.S., what's your zip ?
      2.) To your response to # 1.: So just what is your annual estimated electrical heat load in kWh/yr. to be used for PV sizing purposes ?
      3.) The Dummies book is a bit dated but most of the information is timeless. It is a free, online PDF and a decent primer of residential PV.
      The basics of PV have not changed much.
      4.) I too once had contract negotiations as one of my job responsibilities. For residential PV I've also discovered it's a matter of getting most bang for the buck rather than low buck as an end in itself. That's the errand of a fool. Think value engineering, especially if you plan on staying put.
      • vnatale
        • Jun 2016
        • 60
        1) Yes. United States - 01351
        2) I don't know that yet as I've just started really getting readings on my kWh usage for the three mini-splits only since around this past Monday night. Plus, we've not yet had our traditionally cold January days that we usually have. So I've not got to see their electrical usage when the temperature is much colder. Looking at the ten day forecast the lows are only going to be in the 20 to 36 degree range. No zero degree or sub-zero degree weather yet.
        3) Where do you get the free online PDF version? I did tonight get Kindle Unlimited for two months for $4.99 and acquired two solar books, one of them being the one I mentioned above -- published last month. "Flipped" through it on this computer and it looked substantive.
        4) Yes. People think sometimes think I am "cheap" because I will get so many quotes. No. I'm looking for the best value. Sometimes that means buying the higher priced or highest price item.
        It was relatively easy in choosing among the four heat pump / mini-split quotes because each was quoting the exact same equipment so I got to decide based upon some other qualitative factors.
          • 15005
          1.) Thank you. As a preliminary estimate, as a long-term annual average, every unshaded, installed STC kW ground mount of PV can be expected to generate something like 1,300 kWh/yr. of electricity. That's with a 45 degree tilt and a 180 degree array azimuth.
          2.) So, once you get a design load in kWh/yr. for the project (not before) divide that design load by 1,300 kWh/yr. for a working estimate of system size in STC kW.
          If cost effectiveness is one of the project goals, you'll need a reasonable estimate of the load the system is expected to meet to achieve that goal or balance it with other project/system goals.
          3.) Google is your friend. Try entering "Solar Power Your Home for Dummies + free PDF". Took me 20 sec. and the PDF popped up. But if it's been updated and you have that updated version, you're good to go. What's the other title you mentioned you have ?
          4.) A respectful suggestion: Learn more about the strengths and weaknesses of residential PV before you go further. IMO only, vendors will eat you alive if you try to negotiate with them given your current knowledge level.
          • vnatale
            • Jun 2016
            • 60
            Partial response. More later
            2) Got the book. The other title was mentioned above: "Making the Switch With All Energy Solar"
            This morning completed discussions with both my town's Building Inspector and a member of the Zoning Board of Appeals.
            I am zone RS-1 (Residential).
            The relevant bylaws for a solar ground mount are:
            (b) The minimum side yard and rear yard setback from the property line shall be 10 feet
            The Building Inspector said I have about 35 feet between my house and my neighbor's property line to the south. That leaves about 25 feet for a ground mount. He also stated that it could not extend beyond my house on the front side.
            Zoning District Requirement
            RS-1 Special Permit Required if exceeding 150 square
            feet of panel surface area
            Discussed the possibilities of approval with both the Building Inspector and the member of the Zoning Board of Appeals.
            The Building Inspector said he has not yet seen them turn down any appeal.
            The member of the Zoning Board of Appeals said that they are quite sympathetic to solar. He also gave me a loophole saying that if I were putting solar on a shed then that would NOT be considered a ground mount. Therefore an alternative is to create a shed large enough to hold the panels which then makes it a roof mount, doing away with the need for an appeal process.
            For now I am assuming it will be a traditional ground mount. The member of the Zoning Board of Appeals stated that the more clarity with which I present my appeal then the better my chances of success.
            I am asking the solar vendors to assist me in assembling this information to provide to the Zoning Board of Appeals.
            He said that the quickest that a successful appeal process can take place is first a two week time period to have an ad in the newspaper with letters going out to adjoining neighbors informing them and inviting them to the appeals meeting. Then the meeting would take place a week later. That means it'd be a minimum of three weeks from when I make my appeal to than, hopefully, getting my special permit.
            • vnatale
              • Jun 2016
              • 60
              Sorry. That was not the book I'd mentioned above. This is it:
              • davidcheok
                • Dec 2022
                • 99
                Ground always first with overwhelming advantage except for loss of ground space.
                • vnatale
                  • Jun 2016
                  • 60
                  Thank you for that. The last solar vendor I talked to today was trying to dissuade me from that direction.
                    • 5208
                    PV equipment for consumers tends toward the most elementary.
                    Not ground mount, not snow repelant, not variable tilt. Bruce Roe
                      • 5208
                      You are going down the same energy saving trail as me. 100%
                      solar electric was achieved 9 years ago. Getting numbers on everything
                      reveals a lot. A meter connected for a month revealed that the 4
                      decade old electric range was using far less than 1% of my energy.
                      The microwave was an efficient cooker, but its clock was a vampire
                      load using more energy in a year than the short time cooking. The
                      cure was a circuit to electrically disconnect it from the outlet 7 min
                      after it finished cooking and the door was closed. It stayed at zero
                      energy until the next time the door was opened.
                      Finding and replacing older inefficient appliances really helps.
                      Chasing down vampire loads on some 60 circuits here turned up
                      half a hundred things that could be improved.
                      Your 100A service and transformer size are a limit, but possible
                      with the size equipment you are looking at. My situation is similar,
                      but the numbers are about 2 X yours at this originally all electric
                      home built in the 70s.
                      Sizing my max Solar output at 15KW, was based primarily on the
                      heat load over a year. I knew how many gallons of propane were
                      consumed in a year, and a gallon has the energy of 27KWh. But
                      electric resistance heat is near 100% efficient, and the furnace was
                      less than that, so I needed to generate about 25KWh from solar
                      to replace each gallon of propane. PV estimates indicated I would
                      be a bit short, but the plan was to buy the energy shortfall while
                      continuing to try and improve the efficiency of the house. My chart
                      says about 40 KWh have the energy of a gallon of oil, do not know
                      the efficiency of your furnace. Have you done this calculation?
                      The efficiency gain was done here several different ways. One was
                      to use (6) heat pumps to boost heating efficiency to anything from
                      100% to 400%, depending on how cold it was. There are a few
                      really cold days when the heat pumps drop to 100%, but overall
                      there was a big surplus. It was sufficient that I was then able to
                      maintain a shop well above freezing all year, and a quite comfy
                      working 65F most months.
                      The other improvement was to boost solar energy collected. Peak
                      power was limited to the same above, and also by my net metering
                      contract and inverter size. What was not limited was how many
                      hours I could collect solar energy. Normally peak power only lasted
                      several hours around solar noon. But I replaced a string facing south,
                      with a pair of strings facing east and west. First the east panels
                      deliver energy from the morning sun, then the west panels deliver
                      afternoon energy. With an elevation of near 57 degrees, the power
                      (limited by the same string inverter) is about the same but for twice
                      as long.
                      This scheme gives a big increase in energy collected without an
                      increase in peak power. It is also quite effecive in increasing output
                      under clouds of varied density. It reduces the effectivness of the
                      cheap PV panels, but greatly increases the utilization of all the rest
                      of the system. Even the ground mounts, which may cost more than
                      their panels, can be made double sided for considerable economy.
                      I am finding, my mini heat pumps are excellant for drying clothes
                      hung in front of them, receivng a lot of use in the winter when outdoor
                      lines are unusble due to the weather. So much so, I am considering a
                      couple of short lines to be easily hung near each mini. I do have an
                      unvented heat pump clothes dryer, but it tends to run too cool for the
                      job. Its virtue is not sending a lot of heat outside, the heat pump seems
                      redundant in that all heat remains in the house and and largely in the
                      machine. For summer of course clothes dry outside. Bruce Roe
                      • vnatale
                        • Jun 2016
                        • 60
                        I did get the book. Am on page 85. Have not yet found anything that I'd considered dated. Which underscores you saying that its information is timeless. Thanks for persisting in recommending this fine resource.
                          • 15005
                          You're welcome. Keep learing.Your biggest enemy will be your lack of education.
                            • 15005
                            Probably helpful for DIY, but being off grid is a lot of ongoing work and maintenance that's usually more effort than a part time job. It's a different ballgame than grid tied.
                            • DanS26
                              • Dec 2011
                              • 987
                              Bruce, my wife is a master gardener and grows many shade loving plants under my ground mounts. She has around 10 different types of ferns, some very rare, that love the space. #53
                                • 5208
                                There is plenty of green stuff growing under the array here mounted
                                high above ground snow (42 inches). But that may not be true if I
                                get around to building a 2 sided version. Bruce Roe
