Good idea. I'll will definitely put that on my list.
Yeah, check out this graph of my line voltage at the shop from today:
The main culprit, I think, is that I have 200 ft of MCM350 Al from the 50 KVA transformer on the street to my house. And then another 200 ft of MCM500 Al from the house to the shop building.
Those micro inverters do cut out quite a bit around mid day, even through I worked with Ubiquiti to update the firmware to be less sensitive, but they never could fully fix it. And that was with line voltage less than 264V. Fortunately I have a grid guard code for my SMAs, so I can then them to not cut out above 264 (currently have then set to 270 which seems sufficient).
Snow is generally not too bad here in Central VA. When we do get it, it typically melts in a day or two. I do try to get out there and keep it off the ground mounted panels. The shop roof I leave alone. Although it does sometimes take several days to melt there since the pitch is very gentle.
Your 20 July readout shows line voltage of 129.18 plus 130.19, near 260VAC. Some inverter voltage
monitors are programmed for shutdown at 264, you are very close and subject to any line variations.
What is your snow experience?
