Converting 50kW system from micro inverters to 8x SMA inverters
  • pclausen
    • Oct 2016
    • 153
    #31
    Appreciate the feedback. So I found the full specs of the panels along with this calculator, and got the following results:
    The -12.333 C is the lowest temperature recorded by my weather station in January of this year, that is located next to the panels.
    I don't know what the odds are that all of the following will be true:
    -12C
    Daylight
    No clouds and bright sun
    Inverter not already producing power
    But to be safe, I should probably just do 14 panels per string and then have the last 4 panels in a string of their own.
    3 x 15 panels are the above Talesun 270 Watt panels (6 of them are actually Talesun 275 Watt panels, but close enough) The newly added bottom row is 15 white label 250 Watt panels, so I don't want to mix those with the Talesun panels as it would drag those strings down to 250 Watts per panel. So my thinking is that if I don't go 4x15 strings, to do the following:
    3 x 14 Talesun 270 watt strings
    1 x 14 white label 250 watt string
    1 x 4 string with 3x Talesun 270 watt and 1x white label 250 watt
    • oregon_phil
      • Jan 2019
      • 497
      #32
      bcroe in an earlier post commented "Here strings with 720 cells (12 panels of 60) run MPPT at 360V in summer. But in cold Feb, MPPT can hit 420V. That means
      before inverter turn on, Voc can be 525V. "
      SMA MPPT range is 100 to 550VDC. With 14 panels you could potentially start up at 601VDC on a cold winter day which would put you outside of MPPT range. 12 panels would put you into MPPT range like Bruce's setup. My SMA inverter with OptiTrac/Shadefix checks for global MPP every 5 minutes to make sure it isn't in a local MPP rut. My longest string is 10 panels so I don't have a MPPT max voltage problem. But lets say your inverter starts up with 14 panels at 601VDC. I'm guessing the inverter picks some power value based on voltage(?) and just stays there. Since voltage never goes below 550VDC, MPPT never kicks in (endless do loop). I'm not an expert in this so others can fill in the gaps.
      You are doing a lot of research! Good luck!
      • nerdralph
        • May 2021
        • 157
        #33
        -12C
        Daylight
        A few weeks ago I mentioned how on a cold winter day in bright sun, your panels will be at least 20C warmer than the air.
        AFAIK, both the CEC and NEC require temperature corrections based on the local climate when calculating maximum open-circuit string voltages. That means in northern states and here in the GWN, you have to add 10-15% to the STC Voc ratings. But STC is 1000W/m^2 and a cell temperature of 25C, and even with a good wind, cell
          #34
          I'd be careful about making assumptions and statements like that, especially if operating close to allowable string voltage limits.
          The difference in temperature between an array cell and the ambient air depends primarily on the POA irradiance on the array, the magnitude of the wind vector, the dew point temp. and a couple of other things having to do with something called the effective radiant sky temperature.
          Shortly after sunup on a clear, windless and low dewpoint winter morning it's entirely possible to have the average cell temp. below the surrounding ambient air temp. by several degrees C.
          Reason: Primarily because of low(er) radiant sky temps. under those conditions, thermal radiation heat transfer from the panels to the sky under those conditions may well be greater than the slight amount of POA irradiance on the array under those conditions.
          It's all about doing an energy (heat) balance on the array.
          That's the physics of it.
          • nerdralph
            • May 2021
            • 157
            #35
            That's a red herring. I specifically said "in bright sun", not at the break of dawn. For a given temperature, Voc decreases with decreased insolation.
            • pclausen
              • Oct 2016
              • 153
              #36
              Here's my weather station (Davis Vantage Pro2 with Solar Radiation and UV Index sensors) data for January:
              Weather Underground provides local & long-range weather forecasts, weather reports, maps & tropical weather conditions for locations worldwide.
              I currently have 12 panels connected to each of the 3 MPPTs on a 7700. I tried to retrieve the DC voltages from back in January, but they are long gone.
              Looking at today, these were my peak values, which I know don't mean much, but they were definitely highest early this morning:
              In a perfect world, I'd do 12 panels per MPPT input and with 60 panels in the pole barn array, that would work out to 5 strings of 12. But alas, Each 7.7 can only handle 7,700 watts, so I would be clipping quite a bit and I will have 2 x 7.7 inverters dedicated to the 60 panel array. The 4 x 15 would split the load perfectly between the 2 inverters.
              I'll probably go ahead and do it as 4 x 15 now that its summer and then evaluate changing the configuration come December.
              A couple of shots of the completed 60 panel array:
                #37
                Well, I've provided an example of one of many empirical correlations in the literature used to estimate array cell temps. The one I suggested is one of many I've verified and found it to be reasonably close to what I've measured several hundred times.
                The flaw in your statement is "bright sun". First off What is bright sun ? At what time ? Or more specifically, at what angle of beam irradiance on the array ? and what irradiance level ? Your statement is too general. That's the real red herring. Your statement is, IMO only, vague to the point of being useless.
                You also mentioned "on a cold winter day". The reality that makes that statement irrelevant is that the ambient air temp. by itself has little to do with the ambient air to cell temp. difference.
                That temp. difference is essentially independent of the ambient air temp. I'd explain it to you but space is limited here. Consult a text on convective heat transfer if you're curious. I've got several titles on by bookshelves I can recommend.
                Here's reality and Physics: It doesn't matter if the air temp. is +40 C or -40 C, or any other temp. Under what are otherwise the same environmental conditions of wind vector, irradiance and sky cover conditions, the temp. differences, ambient air to cell will be essentially the same regardless of air temp. There can be very small differences due to what are called the transport properties of (in this case) air as f(air temp.), but those differences are very small and usually ignored.
                But most of that has little to do with my purpose in providing information to the OP about effective radiant sky temperature.
                Since the OP is (or may be) operating at close to maximum voltages, I mentioned that the array temp. can be lower than the ambient air temp. on clear, mostly windless, low dew point mornings shortly after sunup due to low effective radiant sky temps. only for informational purposes and to suggest that array temps. can be lower than a lot of correlations and rules of thumb (and stature) state which might indicate a design change for voltage considerations, especially when operating at close to max. voltages.
                Also, I believe your statements - which you seem to stand by with no corroborating information or logic - only accusation - are sloppy and unsubstantiated, and may lead the OP to problems if he's operating close to inverter max. voltages.
                If you have some meaningful information to back up your hip shooting that makes sense, I'd be happy to read it. Otherwise, I'd suggest being considerate of others and stick to what you know.
                BTW, your statement "Voc decreases with decreased insolation" is incorrect.
                • nerdralph
                  • May 2021
                  • 157
                  #38
                  There's no point in debating if you demand I provide proof/evidence of all my points and you provide none. My points are easily verifiable with public data, such as module datasheets. The IV curves and cell performance data prove Voc decreases with decreased irradiance (I was writing to quickly and wrote insolation by mistake).
                  Even without looking at datasheets, if cell temperature stay the same, it should be obvious that Voc will be lower at night than during the day in bright sun (>800W/m^2 if you want a specific definition).
                  • nerdralph
                    • May 2021
                    • 157
                    #39
                    One thing I like about SMA's Sunny Designer is that it estimates clipping. Usually you can do a 1.2:1 DC:AC ratio with clipping less than 0.5% of annual production.
                      • 5209
                      #40
                      On the ground array, your use of it as a shelter would conflict with my idea of
                      putting vertical snow gaps between rows of panels. Bruce Roe
                        #41
                        OK, here's reality:
                        An energy balance in a PVcell will show that panel cell temperatures will increase with increased irradiance. That's the physics of it. Thank the First Law of Thermodynamics and the principle of conservation of energy.
                        Simply put, stuff gets warmer when the sun shines on it. That's called observational reality.
                        A cell's Voc will decrease with increased cell temperature. More reality.
                        Therefore, panel's Voc will decrease as the irradiance on the panel INcreases.
                        Your first sentence above is incorrect.
                        BTW, and FYI, while some consider irradiance and insolation the same thing, there are others who make definitional differences. For the purposes of this discussion, those differences, while moot, do nothing to change the incorrectness of your statement "Voc decreases with decreased irradiance".
                        Whether irradiance or insolation is the term used, your statement is still incorrect.
                        See pveducation.org, sec. 4.4, "Effect of Temperature" for an explanation of why Voc drops as irradiance (or insolation) increases.
                        I can't explain it any better.
                        • nerdralph
                          • May 2021
                          • 157
                          #42
                          OK, here's reality:
                          Yet another red herring (straw man argument). I never disputed the relationship between Voc and temperature. I have been referring to the relationship between Voc and irradiance, independent of temperature.
                          "For a given temperature, Voc decreases with decreased insolation"
                          I've said that Voc decreases with temperature (around 0.3%/C for mono cells), and you seem to be aggressively agreeing with me. I've also said that if wind and air temperature stays the same, increased irradiance will increase cell temperature. You seem to be aggressively agreeing with me on this too.
                          However you don't seem to understand that when keeping the temperature of a module constant, increasing irradiance, such as from 200W/m^2 to 800W/m^2, will increase Voc.
                            #43
                            I don't think I'm agreeing with you.
                            I do think you have some, but not sufficient understanding of the physics of PV cells and how they operate.
                            If irradiance is increased while the cell is kept at constant temperature, I understand that Voc will INcrease logarithmically as POA irradiance increases.
                            However, such small increases will only occur when the cell is operating beyond it's MPP making that small increase even less relevant for any practical application such as the OP's.
                            Look at any graph of voltage vs. irradiance at constant cell temp. that also shows the locus of MPP's as f(irradiance). You'll find the locus is pretty close to vertical meaning voltage doesn't change much, if at all in any measurable way.
                            Also, because it is a logarithmic variation, that increase is quite small for any practical application like the OP's and is easily buried in negative coefficient of cell voltage with respect to temperature.
                            In fact, and in practice, the (negative) temperature coefficient of voltage, since it's a finished coefficient, includes and accounts for the effects of any logarithmic positive variation of cell voltage at constant temp. due to irradiance increases.
                            All that however, has little to do with either my statement that the effective radiant sky temp. can and will lower cell temps. to levels that are below levels usually calculated from common weather data and methods of calculation, or your statement that cell temps. are usually higher than ambient temp. - which I agree is usually true for most operating conditions but may not be true for near dawn conditions and so especially troublesome when used to estimate (for design) PV cell temps. for systems operating at or close to max. voltages such as what it looks like the OP may have.
                            If you want to talk more about the physics of a PV cell, I'd suggest you open another thread. I'm done wasting my time with this stuff.
                            • nerdralph
                              • May 2021
                              • 157
                              #44
                              Good. And since you seem to like pedantism, it's not exactly logarithmic. You might learn something from studying electronics, as silicon PV cells are just really big diodes (PN junctions). Therefore the IV curves of a common diode like a 1N4148 and those of a PV cell are quite similar.
                              The forward biased IV response of a 1N4148 diode is measured and compared to the ideal Shockley diode equation.
                              As for the magnitude of the effect, with a 72-cell 440W mono PERC module, increasing irradiance from 800W/m^2 to 1kW/m^2 will increase Voc by slightly more than 3V.
                              • oregon_phil
                                • Jan 2019
                                • 497
                                #45
                                For what its worth, I have 10,220 watts of panels on 3 strings with a SMA 7.7. I have some clipping, but not much.
