Can I run this box fan off these solar panels? [240W Panels > 140W Fan]
  • Naruto
    • Aug 2021
    • 25
    Hi All!
    I'm going camping in a few weeks, and have this box fan I'd love to be able to run during the day when the sun is blazing!
    Originally, I thought to build a battery - charge the battery by solar panel and run the fan off the 48V battery. It turns out I won't be able to receive the batteries in time, so I thought maybe I would be able to get decent performance out of the fan just running straight off two solar panels. I understand there is lots of energy loss converting from DC to AC comes with energy loss.
    Here are the items I am hoping to use:
    • Solar Panels - 2 x Newpowa 120W 24V Monocrystalline Solar Panel
    • Inverter - KRXNY 1000W Pure Sine Wave Power Inverter 48V DC to 110V 120V AC 60HZ
    • Standard AC Box Fan - 1.2A 120V @ maximum
    Below is the diagram for the setup I hope to achieve. I have heard that I should put some circuit breakers in between the connections.
    Thank you!!
    Sorry no, the inverter won't work well directly from panels, it needs the battery to handle both surges and deficits.
    Some folks have had success with automotive radiator fans ( 12VDC ), running direct from panels. You would have to address the overvoltage issue somehow, of 24V panels feeding a 12V fan.
    Truck stops and trucker supplies have some selection of 24V fans too, likely less expensive than a 1kw pure sine inverter
