I have a newer 6kW Enphase/Panasonic system and an older (2009) 4kW string system. The system is installed on an uninhabited metal building. I'm planning on getting 2 Powerwalls. My understanding is the Powerwalls will work with both inverters but I'm concerned about the old string inverter. It went out a few years after it was installed and was replaced under warranty with a new unit of the same model (Yes! ES 4000P). It is now out of warranty. I haven't yet decided whether to just replace it when I get the Powerwalls installed or wait until it goes out. Either way, I'd like to be ready so I know what to do.
The old inverter is not a smart inverter, there no optimizers (and I don't have a shading problem), and the system is not rapid shutdown compliant. My county is under NEC 2014 for new construction.
1) Will a smart inverter work better with the Powerwalls than a older type inverter?
2) Do I have to comply with the NEC 2014 rapid shutdown requirements if I replace the inverter or am I "grandfathered" in?
3) I was looking at the Sunny Boy 3.8-US-41 inverter, it seems like it would be a good fit. Are there other/better options I should be considering for my situation?
Thanks
Thanks
