New Solar Edge inverters (no screen)
  • arf88
    • Nov 2017
    • 190
    My inverter blew, yep i heard two loud pops as it was resetting itself, multiple error codes. My solar company called Solar Edge, got it RMA and now I'm getting a new inverter installed today.
    What I'm not thrilled about is the lack of LCD screen and button up front. I would check this everyday to ensure it was in night more and all solar panels registered. Was told by the tech they did this b/c the sun would hit the LCD screen and cause damage over time.
    Apparently the newer models update every 15 mins instead of 4 hours over cell which is a plus but I would rather have the screen personally.
    For those with the newer inverter is the portal the same or is there more information provided in the app?
  • arf88
    • Nov 2017
    • 190
    One thing i checked daily was the night mode and number of registered panels. It turns out without the LCD screen it is not possible anymore to check this unless you are the installer with the SetApp. They don't have anything for the homeowner yet, apparently there is a new app but not released. And to even use this you have to press a button and be within proximity to check if you had the SetApp password and installer credentials. Not sure why SolarEdge made this change. ehhhh
      Another happy SolarEdge customer.
      • solar pete
        Administrator
        • May 2014
        • 1827
        Hi All,
        I think the no screens idea is crazy, we dropped the new range of SMA inverters when they went to screen less, a common scenario in OZ is that people put their solar on a shed say 10 or 20 meters away from the house, no internet connection, no wifi, and if the people are not into using these new fangled phones how do they know whats going on, very stupid idea this no screen business from my point of view anyway, ok gripe mode off
        • arf88
          • Nov 2017
          • 190
          I'm dumbfounded solaredge would make this change. So right now I have no way to monitor if all the panels are registering and I have to rely on the monitor app which barely provides enough information with its 4 hour updates. This is just a terrible change.
            • 5209
            Originally posted by solar pete
            Hi All,
            Same here, I picked up a new in box pair of inverters just like the ones running, in
            part so I would not run into any so called upgrades in replacements.
            The reasons (excuses) given to justify such things, are just the best sounding thing
            they could think of, and have nothing to do with the real reason. Sort of like Politics.
            Bruce Roe
              • 3802
              It sounds like your installer has not given you full owner access to the monitoring portal.
              • arf88
                • Nov 2017
                • 190
                I have the monitor portal access but that does not tell you what the LCD screen would. The setapp replaces the LCD screen and I'm going to keep asking until the credentials are provided.
                  • 3802
                  There are different levels of the web monitor portal access. With full owner access you actually get more information than the LCD.
                  • arf88
                    • Nov 2017
                    • 190
                    In that case you are right I have never had that much access through the monitoring app. Frankly I would prefer the LCD but if the app offered the same info I'm better than not having anything at all.
                    • hardwired
                      • Oct 2019
                      • 36
                      What are the levels?
                      I would want full access.
                      Also, what is the connectivity -ethernet, wifi, cellular?
                      The utility is mandating some external meter remote monitored with cellular.
                      With Solaredge can I monitor both generation and consumption? Is it periodic or realtime (load comes on and you see htechange instantly, or vice versa sunilluminates a PV panel and the watts out is immediate on those panels)?
                        • 3802
                        Connection can be ethernet or cellular
                        you can add a revenue grade meter for SREC generation and it can be remotely monitored
                        you can add a consumption meter as well to get both production and consumption.
                        the monitoring is periodic near realtime with ethernet and every 15 mins with cellular.
                        • arf88
                          • Nov 2017
                          • 190
                          The monitoring is periodic near realtime with ethernet and every 15 mins with cellular.
                          You must be talking about the new model without the LCD b/c the one with LCD updated every 4 hours on the portal over Cell. I just got the new one put in and I think you might be right it is more frequent than 4 hours but can't validate every 15mins until i test it.
                          I sent the solar company an email letting them know about the level of access. Waiting to see what they say.
                          • hardwired
                            • Oct 2019
                            • 36
                            Can you still buy the larger 10k and 11.4k version with the LCD panel? Would mount it indoors if it's not generating much heat.
                            Im not familiar with what info the Solaredge App can can provide over Ethernet. Are there any options one needs to buy for homeowner monitoring?
                            • arf88
                              • Nov 2017
                              • 190
                              As far as I understand the only stock left of the older models with LCD is used models, all the new ones have no LCD.
                              ButchDeal you mentioned you have more info than the LCD using the monitoring app. Can you be more specific what it allows? Thanks
