SolarEdge Active Cooling Mod
  • jragsdale
    • Jul 2019
    • 5
    Since the passive heatsink seemed to be doing a rather poor job at heat dissipation and the SolarEdge has a temperature limit where it will derate and lower power output, I decided to add a DIY active cooling solution to my inverter. I paired 4x60mm fans that each blow about 17cfm along with a thermal controller with remote sensor so it will turn on at 105*F and off at 85*F. Undoubtedly it will impact the passive convection cooling, but should anything fail there is still enough gaps around the unit to allow airflow and the whole assembly comes off with 2 screws. I've seen about a 20*F reduction in temperature from the readout on the LCD when the fans are running.
  • Markyrocks69
    • Jun 2019
    • 226
    That's pretty cool, probably make your warranty void but looks like you did a decent job.
    • azdave
      • Oct 2014
      • 790
      Were you having trouble with the unit derating or was this added "just in case"?
      Dave W. Gilbert AZ
      6.63kW grid-tie owner
      • jragsdale
        • Jul 2019
        • 5
        Dave, I hadn't noticed any derating or flattening of the curve in the monitoring platform, but it was getting into the 140*s some days and it wasn't even the hottest days around the solstice. More of a fun way to just in case and to extend the life of the inverter. Might consider adding more panels in the future too.
        • azdave
          • Oct 2014
          • 790
          Originally posted by jragsdale
          Dave, I hadn't noticed any derating or flattening of the curve...
          Okay. Just curious why you added the fans so now I know. My inverter is mounted in the garage which gets just as warm as it does outside but without the extra heat of direct sunlight. My garage temps reach 105-110 just about all summer long and I have a passively cooled Power One inverter. No issues here and it's rated to run at 140 ambient so I never felt I was on the edge or anything. Obviously, electronic don't like heat so no harm in lowering temps if you wish.Thanks.
          Dave W. Gilbert AZ
            • 3802
            Well the harm is the losses in efficiency and added dirt to the components, and worst more thermal cycling in the board. I think first two are minor but shouldn't be discounted. The fans are about 1watt so 4watts for maybe 5 hours a day or 7.3kWh / year.
            I would change the settings to be on at ~115 and off at ~105 or so the mother board has less thermal cycling. it will warm up each day and stay pretty warm (but less warm than without the fan).
              Our local temps are heading up to the 100's and I just plug in a timer and 40W fan, and aim at the electronics, with the theory moving is better than static over the heatsinks
              • Markyrocks69
                • Jun 2019
                • 226
                I think I'm going to remove the old case, replace it with some clear plexiglass, put some rgb in there and put a custom waterloop on mine. Maybe get like a motion sensor and a small sound system that plays "I'm sexy and I know it" when it is triggered and the rgb will flash and change colors to the music
