You're not following.... The interference is coming from the smart meter, going through the AC lines to the inverters. Nothing is radiating.
Ferrite Choke questions
The panel inputs can be filtered if that is what is needed. RF is slippery stuff, it doesn't follow niceThat's what I was afraid of. I suspect everything is radiating, including the micro inverters themselves, so they have to be placed in a shielded enclosure, their wires run through toroids, but worse, the noise is probably back-feeding into/onto the panels themselves. Not sure what can be done about that.
simple paths. Getting some real filters will produce better results. Bruce RoeComment
What's the system you're trying to protect from the RFI? How far is it from the system? And why do you suspect the smart meter?
Does a handheld broadcast FM radio pick up roughly the same RFI?Comment
This sounds very odd to me. I thought smart meters only radiated, using internal antennas, in the ISM bands. I don't think they would be able to operate on lower frequencies on the power lines because I don't think it would make it past the service drop transformer. How did you measure the conducted RFI and what was the frequency that you saw? I'm not saying you're wrong, but I'm having a hard time understanding how it would work.Comment
Generally, a smart meter uses a signal like Zig-Bee in the 2-5GHz band. I don't think it uses ac cable "carrier current" communication - cause that would stop at the transformer.
You (or a neighbor) may have some other gadget installed that uses carrier current (wireless intercom, X-10 home automation) and that's mucking up your inverter comms.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Nope, some use BPL which is carrier current. It's a strong enough signal to pass through the service transformer and reach the distribution substation, but not further.
See this link from ARRL and search for "BPL" http://www.arrl.org/smart-metershttps://pvoutput.org/list.jsp?sid=54099Comment
Actually it's PLC, but could be BPL elsewhere. PLC is "power line carrier".https://pvoutput.org/list.jsp?sid=54099Comment
It seems that PLC operates under Part 15, so if they can't make the meter not interfere with my inverters' operation, then I can have them remove it...
https://www.youtube.com/watch?v=T2D9DEltOZM is a video of the AC line with these comms. And, yep, my lights flicker when the meter is talking.https://pvoutput.org/list.jsp?sid=54099Comment
According to that ARRL document, smart meter power line communication is rare or nonexistent in the U.S., so that wouldn't be on my short list of problems to fix. Have you actually measured a communications signal on the power line at the meter?Comment
Yea, its not using BPL, its PLC. The meter manufacturer and SolarEdge are now collaborating on a fix. The meter manufacturer gave Enphase a filter algorithm for this exact issue, so SolarEdge will need to do so as well.https://pvoutput.org/list.jsp?sid=54099Comment
If the meter can broadcast enough power on the AC line to make lights flicker, that's just awesome !!Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Enough talk already. If its affecting your lights, it shouldn't be too hard to see the
nature of it on a scope. That in turn could lead directly to a fix. Bruce RoeComment
No need, I linked a video to youtube with a scope showing the signal. Also, here's the patent on the communications method.
As disclosed, a two-way automatic communications system (TWACS) and method are used by an electrical utility in which outbound messages are sent from the utility to a consumer and inbound messages are sent from the consumer to the utility. The respective outbound and inbound messages are sent and received over the utility's power distribution system. A receiver including an analog filter component, an A/D converter and a digital processor detects the outbound messages. A substation transceiver is configured for sending analog outbound messages from the utility to a consumer. A transponder is configured for sending inbound messages to the transceiver from the consumer to the utility, the respective outbound and inbound messages being modulated on a mains signal of the utility's power distribution system. The receiver in another form includes an analog filter component, a detecting circuit and a demodulator.
It's a Part 15 device, so if Alcara and SolarEdge can't get a filter algorithm for it, I can have it removed due to the interference it's causing.https://pvoutput.org/list.jsp?sid=54099Comment
