Tyab, thanks for the recap. Just to be clear, microinverters in the past have also been the source of a ton of RFI. There are examples of folks with M215's using toroids on the output leads as referenced in an enphase application note (which is no longer apparently on the enphase website) reducing the interference adequately, but there are no examples that I can find on any modern enphase units being deployed and not causing noise either.
Hams and those caring about AM reception have traditionally gone with string inverters, which seem to be out of favor for the reasons cited here, esp in California.
I am now thinking I need to actually test a bunch of units and see empirically what happens. This would be a good thing for a university to actually do a report on, and maybe the FCC as part of an enforcement action. I don't think the Trump FCC is likely to soft pedal enforcement on solar companies if interference is deemed a problem. Unfortunately it could give the anti-solar forces a new lever to pushback on solar deployment, all because the inverter companies got sloppy.
thx
mike
thx
mike
