Can you stack hybrid inverters in a large PV system?
Oh, awesome, so the DC busbar voltage is always higher than the voltage of the batteries. I guess that makes sense because it would be impossible to charge them otherwise. ThanksComment
Not always, only when charging. at night when solar is not producing and you are not charging from an AC source, the DC bus is at battery voltage.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Not quite right. When the PV is not producing any energy and the grid is also down there is nothing to keep the bus voltage above the (resting) battery voltage. Instead the battery would be drained to supply the inverter to keep the backup load going until sunrise, grid restoration, generator startup or some other event.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
