Current system is 40w panel charging 12v 18ah battery through charge controller being used to run 6-3W LED lights for 3 hrs a night through 700mA flex block buck boost led driver. During sunny days battery is fully charged so thought I had some extra power available. Bought a small garden fountain (shiny sphere that water bubbles out the top and runs down). It is run by 120V AC 0.082A 60hz pump (jebao WP-450). http://jebaopump.com/products/wp-450...-fountain-pump
Original idea was to use an dc to ac inverter to power it but not sure if that would work and would be cheaper to replace the pump with a dc pump.
Want pump to run during the day so don't think I can connect to above system as lights run for 3 hours after the panel output drops. I do have another panel, battery and charge controller so I could set up another system. Not sure on exact specs of panel but slightly smaller than the above panel. Batter is 12v 3ah.
If you set charge controller to have load on during the daylight hours, any idea of amperage coming out? Comparable flow rate dc submersible pumps on amazon have a 400mA to 1A max. Do u need something like the led driver to reduce amps??
Any advice on different setups or suitable pump would be greatly appreciated. I can try to provide further details if needed.
