I have a relatively small SolarBridge system:
About 2 weeks ago the SPM-103-ET showed error message: 0P-0013-10. From checking their portal it had last uploaded data about a week before that.
I rebooted it and it then showed 0P-0012-10 - which it has had since. After a reboot it appears to start normally, and gets all the way past "Applications starting." After few seconds after fully booting - instead of displaying power output - it displays the error message.
I got in touch with Solarbridge support. They initially said it was a fixable problem having to do with the some filesystem maintenance - no big deal. They called me back a few days later to say they wanted to replace the unit. It's warrantied for 3 years - and mine was slightly older than that - but they were going to replace it anyway (except they wouldn't pay for labor). I helped the installer (now changed businesses) with the initial install and am happy to install the replacement. They won't let me do it and will only ship to a local installer who naturally wants to be paid to do the work.
Long story short, i'm looking for troubleshooting / repair advice as i'm not keen on this thing failing after 3 years - and i'm assuming having a few more of these "fail" over the life of my solar infrastructure.
The unit appears to be in a mostly functional state:
I have a feeling that with terminal access i could figure out what's going on with it. Is anyone familiar with troubleshooting these. I've been looking for the service manual but can only find the installation manual. I also can't get a description of the error messages. I've asked SolarBridge a number of times but they've failed to provide them.
If anyone has the service manual, and/or any advice on this unit i'd appreciate it.
- Grid connected
- 14 panels w/ micro-inverters
- SPM-103-ET manager
- It was professionally installed ~3.5 year ago and has generally worked fine since then
- The on-board menu interface works fine
- It's connected to my home network but the web interface won't work (ssh access does work but i don't have a credential and the default one doesn't work).
- UPDATE: The web interface does work, i tried it again last night and got it. It didn't have any real-time data but it was fully dark out.
- Solarbridge support confirms it connects to their portal and they can access it
- It's not monitoring or sending energy data.
