I have 2 panels, both 300Watts Specs as follows
MPP Voltage = 32
MPP Current = 9.4
Open circuit voltage = 39.8
Short circuit current = 9.98
Max system voltage 1000v
I already have a 12volt inverter, and battery setup of 311.8 AH at 12V with things running on 12V as well.
I am not worried about getting every Watt i can out of the controller, and have no issue over paneling its rating if allowed. IE: 14.4V @ 30 amp output =432W but 600W of panels.(40Amp would be a bit better in my situation) Throwing some energy away as *heat?*(I assume) but having more panel for when its cloudy.
From my research , the Renogy Tracers and Commanders and such do not list on their site as being able to go over their rating - BUT - The actual manufacturers of the product list it being fine by up to 3X the rated amount before frying the controller.
I have no plans to ever update the system to 24 or 48 volts and buy new equipment . This is a camp with a set amount of things that need to ever be powered.
Please help me choose/recommend me an acceptable MPPT charge controller for my 600W of panel .It's other requirement is the ability to handle the 39.8x2 Voc, + the leeway for the -55F temps that are possible. My budget is only around 200 dollars, but something of amazing quality and that is Ideal i could go to about 300. I do not wish to spend 500 dollars.
Thanks for any assistance you all can give , as i am in a rush to get this setup by next week and my head is spinning doing all the planning.
MPP Voltage = 32
MPP Current = 9.4
