diy solar grid tie
  • sdold
    Did you do the uplift calcs? What did you come up with?
  • billy1
    So for 2 rows of 6 panels 20' rails and one row of 3 panels 10' rails. If my rafters are every 2' how many flat tile hooks do I need?
  • billy1
    Originally posted by foo1bar
    I created a spreadsheet with various options when I was evaluating which to go with.
    I had 285's and 260's and 300's as various options. And projections of how much of the electric bill they would eliminate. And how many months until the "breakeven" point.
    For me, the 285's were a good point in the price/capacity curve.
    If I had more roof space, 260's would have been just as good, and I probably would have gone that way. (I'm somewhat glad they didn't fit though. Looking back it would have meant even *more* mounting points and racking to get setup. And that took quite a bit of time.)
    If you have a south-facing roof or even better, a south-west facing roof, with being in PG&E, you will want to go TOU.
    TOU makes the calculation of how much $ are saved for a given array size more difficult. (or what array size gives you $0 bill)
    You can download your green-button data from PG&E and do a spreadsheet to calculate - but it will be a bit of a PITA.
    While you're doing your planning you need to evaluate how you're going to tie into your current service.
    1> do you have a large enough service to do the backfeed?
    2> Is your main breaker panel an end-feed panel or center-feed?
    3> What is the "120% rule" and does it apply to your situsation?
    4> What size breaker do you need for the backfeed?
    etc.
    Good luck.
    Hey foo1bar, I got to a point where I need to understand my main breaker.
    1. I have plenty of room left on my 200 amp main breaker for the back feed, I'm using 140 amps of 200 amps. I think I need 30 amp breaker for PV and I will add a 50 amp breaker for 14-50R outlet for a EV in the future. That would bring me to 220 amps total I believe.
    2. Not sure end fed-feed or center-feed, If the take the panel service cover off it will be clear right?
    3. So it should be 240 amps for my 120% rule?
    4. I believe I need a 30 amp breaker for my PV system
    It's going to be Solar World 285 watt and Enphase m250 15 each
  • billy1
    Hey John, I'm curious to know which EV you have, yearly mileage, and yearly kWh your electric utility bills you for jus the EV.
  • john95
    @billy:
    I pay about 125.00 not in summer. In summer I pay about $180 for the hot months. 4 AC units that keep us cool & EV.
  • sdold
    Thanks Suneagle, you're welcome. Billy, he was pretty thorough, but very reasonable, not looking for reasons to fail the inspection, just making sure everything was according to plan and the code. I've dealt with maybe ten building inspectors over various electrical and construction projects and all have been reasonable.
  • billy1
    Thanks Steve, looks a pro did it. Did the inspector go on your roof or just look at the PV array from the ground and look at the breaker box for a minute?
  • billy1
    commented on 's reply
    $63 a month on average W/O EV
    Nice drawing set Steve.Thanks for sharing them
  • john95
    Originally posted by billy1
    HiI' I'm new here.....So I want to install my own PV array. Can you suggest websites to buy the hardware? I'm in solano county California zip 95688 and I'm willing to pick it up at a store if it will be cheaper (buy in CA=tax though).
    I used 3,996 kWh past 12 months with PG&E and I plan on getting a Tesla Model 3 later like in March 2018 (fingers crossed), and drive 9,000 miles a year. I'm guesstamating the car will get 32 KWh per 100 miles driven. Sounds like the car will use 2,550 kWh a year based on my timited googel fu, but when I asked wholesalesolar.com how big a system facturing in the EV he could not give me a answer, and said I won't know until I get the car :/ I'd be nice to just built the max system I need and have a zero electric bill, I emagine I would need to pay for a second permit to add on? My cost to pay for the first permit is only $212 though.
    My house is facing south with flat tile roof, normal roof slope I guess, and plan on going through the attic and fishing the romex wire in the garage wall to main breaker box that's facing outside of house.
    I can fit 2 rows of 6 panels and the third row of 3 panels, 15 total panels portrait of 60 cell. Or, I guess I could also just do to 2 rows of 6 panels 72 cell (less mounting/rail hardware
    So with micro inverter I don't have to use AC disconnect switch right? But central inverter I must have a AC disconnect switch?
    Anyone no of price and availability on the LG 320 AC W/ built in S280 micro inverter?
    Anyone currently using LG 300 AC W/ built in house micro inverter? Or know of a review online, I'm interested how that's working out.
    I think I'm going to use flat tile hook with deck level flashing. My house has battens on roof like little bit less than 3/4" thick, with I have to shave the flat tile? should I use side mount hook?
    What rack should I use? I have been looking at snapnrack and Iron Ridge. I got a quote for a whole system solarpanelstore.com (shipping not factored in yet but no tax) but the cost for snapnrack parts seems really high.
    [ATTACH=CONFIG]n329635[/ATTACH]
    And here's one from wholesalesolar.com which is way more criptic, and I have no idea what's up this the $100 wire diagram revision. I asked them for 3 quotes ;/
    [ATTACH=CONFIG]n329636[/ATTACH]
    [ATTACH=CONFIG]n329638[/ATTACH]
    [ATTACH=CONFIG]n329639[/ATTACH]
    I have been doing a lot of research, I think I just hit the wall. Thanks for your help.
    Just out of curiosity, how much do you pay a month for you electric bill?
    Sound good, how do I PM?
    You don't. That's an unavailable feature.
  • billy1
    Originally posted by sdold
    You'll probably need engineering data too showing that the structure will support the loads. I used the Mounting Systems hooks because I didn't want holes in the tiles. I used Prosolar Rooftrac rails with the tile hooks that bolt to the bottom of the rails. If you want a copy of my plans to use for ideas, send me a PM with your email address. They are similar to what most AHJs would require and it's nice to have a starting point. I did all of my calcs and drawings, it wasn't too bad.
  • sdold
    I was able to speak to the office assistant and she said I need roof plans showing location of panels, single line diagram of all electrical information, and specs of solar panels and racking
  • billy1
    Hey Steve,
    I'm trying to get ahold of a building inspector, there playing hard to get, I'll try again. I was able to speak to the office assistant and she said I need roof plans showing location of panels, single line diagram of all electrical information, and specs of solar panels and racking, best part she said I can upload it all to there city website. For the Envoy I was going to take a dedicated outlet that's a single plug outlet in the garage (other side of that wall is where my main breaker box is) for the sprinkler timer and change it to a dual plug outlet. I don't plan on using a AC disconnect ( I figure why bother). I just tried going to http://www.mounting-systems.us/ but the site is down, what made you chose them over what Renvu offered? Which hook type did you use? I'm not sure why use one over the other (bottom mount, side mount, w/ or w/o adjustable). I checked out Renvu last night (very organizer) I saw that they charge $250 for a electrical line diagram, did you pay them for just the diagram and submit it the the city before you bought anything else? I still have to figure out the roof plans diagram for panels as well. What product did you use for roof penetration flashing, I know quickmount has one but the video shows you need to cut a square in the middle of the flat tile shingle :/
  • sdold
    Hi, I did the same thing just over two years ago. I suggest checking with the Vacaville building department for requirements before beginning the design and having your plans approved before buying anything. I used Renvu too. When I installed my 4 kW system, PG&E didn't require an AC disconnect. I did use a small sub panel though, which made it easier to do monitoring using the Envoy. I used Mounting Systems tile hooks on a flat concrete tile roof. I was going to notch the tiles for the hooks until I went to the Mounting Systems warehouse in West Sac to pick up my tile hooks, and looked at their example installations where they did not notch the tiles, so I didn't. You can barely tell and we've had some real downpours over the last two years and zero problems. Not telling you that you shouldn't notch them,, just telling you of my experience.
    Good luck!
