(4) 300w solar panels MPPT controller and 24v battery bank from golf cart batteries
Generally, a battery system can be "over paneled" a little bit. The MAJOR mfg's (Midnight, Morningstar, Xantrex, Outback) all will fold back current, to keep the controller in a safe range.
In the morning, the sun comes up, and the controller starts a slow charge on the batteries, by 10AM with better sun orientation, the panels could really be pushing power, but with the batteries partially charged by this time, they seldom take the full current the panels could put out. And the panels normally run 80% of spec, because they heat up and "fade" a bit.
The LOAD terminals are located ANYWHERE the mfg wants to put them, you cannot rely on them being the 2 righthand terminals. And AFIK, they are always at battery voltagePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
OK I have come to my senses. After remembering the road noise from the crap tires I bought for my wife's car that saved me $100, I've decided to pay more up front for this charge controller.
How about this Midnite 200v 79a for $550.
Being able to wire my 4 panels in series @ 160v open circuit will benefit me, eh? This controller should be over kill, but after finding a 10 year old unit sell on ebay for over $200, I assume its a good choice to make.
Just a reminder, here are my panel specs- STC DC Watts Maximum Power Pmax: 300 W
- Module Efficiency: 18.4%
- Maximum Power Voltage Vmp (V): 33.67V
- Maximum Power Current Imp (A): 8.96A
- Open Circuit Voltage Voc (V): 40.0V
- Short Circuit Current Isc (A): 9.35A
- Maximum system voltage: 600V UL, 1000V IEC
- Maximum reverse current: 20A
- Power Tolerance 0 +3 watts
- Cells per module: 60
- Glass: Low iron tempered with Anti-Reflective Coating
- Dimensions: 65.95 x 39.4 x .29 inches (33mm)
- Weight: 39.7 lbs
Classic 200
The Classic 200 MPPT Charge Controller has Arc Fault, Ground Fault, free web monitoring, a graphics panel and Solar, Hydro and Wind Modes. The Classic 200 has a maximum output current of 79 amps, an operating voltage of 200 volts and works with 12 to 72 volt battery systems. The FREE MidNite Solar Local Application enables you to monitor your Classics over your local network or the Internet. As with the whole Classic Line, the Classic 200 has MidNite’s exclusiveHyperVOC which extends VOC limits when needed.
So (4) 300 watt panels producing 1200 watts divided by 24 volts is 50 amps. 2 battery banks @ 24 volts made up of (4) 6 volts 220 amp hour golf cart batteries each allows approximately 25 amps per battery bank charging power.
How do I determine what gauge wire to use to connect the batteries together?
Where should I place a breaker / breakers?
Am I missing anything else, before I get too far into the installation.Comment
(I'm not a pro or even very experienced so do take this with a healthy grain of salt)
Above my comfort level to reply.
I'm interested to see how these panels work for you.Comment
breakers & fuses are placed as close as practical to the origin of power. The batteries would be the item to place the breaker/fuse closest to. There are even some fuses designed to bolt onto the battery terminal, and then your cables connect to it.
Easily and economically satisfies ABYC 7 circuit protection rule by mounting on a 3/8 battery post, battery switch or bus bar.
single or dual fuse,
Being able to wire my 4 panels in series @ 160v open circuit will benefit me, eh? This controller should be over kill, but after finding a 10 year old unit sell on ebay for over $200, I assume its a good choice to make.....
You are working with a 24V battery ? When you go with voltages more than 2x battery voltage, you start to incur losses in the charge controller voltage conversion
If it was I, I would wire panels 2x2 (2series, 2 parallel strings) into the controller via 1 breaker (for test and maintenance)
1200w @ 26V = about 45a of charging.
I'm running 160V pf PV into my Classic 200 and it's as hot as a firecracker with a 48V battery. But I had no more space in the underground conduit for fatter wire, so I HAD to go higher voltage. Knowing what I do now, I would suffer the loss in the wire, rather than heating the snot out of my controller (higher temps = earlier failures)Last edited by Mike90250; 08-24-2016, 02:51 AM.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
NO
<<So, I'd wire 2 in series, and then parallel 2 of the series strings, giving you close to a 66v array @ 18A to run to the charge controller. You can wire 2 strings n parallel without needing fuses or <<breakers. It's nice to have a breaker on the PV and Battery sides of the Charge controller, for ease of shutting it down.
<<Most reliable MPPT controllers will self-limit to operate in a safe region even if overpaneled
Thanks for the info, Mike. I was assuming it was better to run my panels in series, running the open voltage to the max. In an earlier reply, you mentioned configuring the panels to produce 66v. I didn't realize it was best to double the battery bank voltage, which yes, is 24v ....
I can actually save some money buying a lower cost controller if I don't need 160+ volts from wiring the panels in series...
