Well, EDLC's have far higher charge density, but have similar problems.
However, the path towards elimination is not replacement with an equal charge density, more reliable part; it's removing the need for them to begin with. Capacitors are needed in inverters because energy storage is needed, and energy storage needs are inversely proportional to frequency. In general, an inverter with a switching frequency (not inversion frequency) of 500KHz needs one-fifth the bridge capacitance of an inverter that runs at 100KHz. Once your frequencies get high enough, electrolytic caps can be replaced by film caps or even ceramics, both of which have much longer lifetimes. For example, SolarBridge (recently acquired by Sunpower) uses only ceramic and film caps in their microinverter designs.
