Hi, Im new to the solar power installation world. I have been reading through most of the permanent posts, but I decided to go ahead and get a thread started while I continue to peruse the site. So Im going to first list the components I am planning to purchase, then write about the set up Phases I want to install and then voice my questions and concerns. Thanks for taking the time to help out and ALL tips and advise are welcome!
Renogy 100 Watts 12 Volts Monocrystalline Solar Starter Kit PWM (MPPT20 or MPPT40 are also available for an increase in price)
Renogy 100W Monocrystalline Starter Kit is designed specifically for customers new to solar. The Starter Kit is great for off-grid applications, such as RVs, trailers, boats, sheds, and cabins - providing many benefits, including, but not limited to, quiet power production and grid independence. This solar kit comes with the tools necessary for a new system: a Renogy 100W 12V Monocrystalline Solar Panel, a 30A PWM Wanderer Charge Controller, a 20ft 10AWG MC4 Adaptor Kit, an 8ft 10AWG Tray Cable, and a set of Z-brackets.
The charge controller has been upgraded to Renogy's new 30A PWM NegativeGround Charge Controller the Renogy Wanderer
With the Renogy Wanderer 30A PWM Charge Controller, you can expand your system up to a maximum of 400W
The kit now includes an 8ft 10AWG Tray Cable to connect your charge controller and battery
Ideal output: 500Wh per day can fully charge a 50Ah battery from 50% in 3 hours (depending on the availability of sunlight)
Negative grounding controller ensures the broader off grid applications and safety, especially to be used on a vehicle which has battery negative on the chassis
12V 100Ah SOLAR WIND AGM SLA DEEP CYCLE VRLA BATTERY 12V 24V 48V
2x Signstek 25ft AWG 10 Double Layer MC4 PV Solar Cable Extension for Solar Panels with Solar Male & Female Connector
2x 2009 24v 30Ah military spec aircraft batteries - need to see if they are still capable of holding a charge, but if they can, bonus for later on!!
I would like to have landscape lighting for 2-4 hours each night.
PHASE 1
Front yard
Hampton Bay 590-313 (auto @ nite)
Input 120v AC, 60 Hz, 2.6 A
Output 12v/14v AC (use only 12v MR 16, MR 11, T3 type - 300 W max lamp load...not for use with dimmers
6x 20w halogen bulbs = 120W
PHASE 2
Backyard (remove low volt transformers and use lights connected direct to above system)
Malibu low voltage timing transformer ML88T
Input 120v - 60Hz, 1.0 A max
Output 12v, 88w max
15x 4w landscaping lights = 60 W
Twilight low voltage lighting system CB-150MD
Input 120v - 60 Hz 1.5 amp
Output 12v AC, 60 Hz, 150 watt
PHASE 3
16x 23w CFL lights over a distance of 200 yards around yard with wiring already installed.
PHASE 4
front gate (w/ back-up batteries)
I am looking to change all bulbs to LED lighting in stages as we add more to the system over time.
Concerns:
Would someone mind explaining the difference between PWM, MPPT20 and MPPT40 for the panel system, please? From what I understand, the 20 and 40 are more efficient for charging. Right now, I dont mind using the cheaper one until I need something more advanced and learn how the system works to a higher degree.
I am confused and lost when it comes to an inverter, so I need some basic, talk to me like Im a fifth grader education on this. I figure it is a bit different since Im not just going to plug a cord into an inverter for the use I have planned.
Is the panel listed above sufficient to charge the battery? We live in SE GA. Typically mornings and early afternoons are good for sunlight. I would expect anywhere from 6-9 hrs of sun a day.
Does 2-4 hours seem a reasonable time for these types of lights to be on with the 100Ah deep cycle battery described above? If not, what would be required?
Will the distance between the CFLs and landscape lighting significantly affect the system as planned? I understand I will probably need to expand to more panels for more chargability and batteries for longer sustained usage.
The 24v batteries still need to be tested for chargability, but if they are able to hold a charge, do i need a 24v panel to charge them?
I think thats it for now, but thank all of you so much ahead of time for the help.
Best wishes and regards,
Mike
PHASE 1
Front yard
PHASE 2
Output 12v, 88w max
PHASE 3
PHASE 4
Concerns:
Mike
