Hi :')
I want to ask about how to calculate the efficiency of a solar panel ?
η = pout / pin
now how to calculate Pin ?!
I know that "the input power for a 100 × 100 mm2 cell is 10 W and for a 156 × 156 mm2 cell is 24.3 W"
For yingli solar "YL310P-35b" as an example.
η = 309.639 / Pin
Pin ٍshould i calculate it based on the are mentioned in the data sheet (area of the cells with the frame)
0.99*1.960 (Width * Length) * 1000 = 1940.4
then η = 0.16
or should i calculate it as follows:
" 6 * 12 (number of cells in the module) * 24.3 W (the input power for a 156 × 156 mm2 cell) = 1749.6W
then η = 0.18
In the datasheet the efficiency equals to 16%, why they have used the area of the solar panel with the frame to calculate the efficiency while the frame actually is not used in the conversion of radiation into energy ؟
η = pout / pin
η = 309.639 / Pin
then η = 0.16
then η = 0.18
