Suntech 280 watt panels and design ideas
The only thing that makes a 280 watt panel 280 vs. 230 is the physical size. If you can only fir 12 230's, then you can't fit 12 280's. If you can fit 12 280's, then you can fit 15 230's.
Also, using an enphase microinverter on a 280 watt panel is a waste. The max output of the inverters is 199w. They're optimized for a 230w panel. Trust me, I use enphase on all of my installations and I don't use suntech 280s for a reason.Your single source for sustainable home improvements: [URL="www.eco-merica.com"]www.eco-merica.com[/URL]Comment
That can be said about alot of modules. The difference is about 50 watts. Why use enphase on all your installs when you max out at 200 watts. Seems odd. I believe enphase to be good for shady areas. That's the only reason. Your driving the cost up to the green customers, when its not necessary. Why limit yourself to 200 watts, extra eqipment and loads more wires. Especially with enphase lack of a track record?MikeComment
Another benefit of enphase is module level MPPT. This way each module is performing at it's best within the power tolerance range.
I just installed a 23kw residential system with enphase for the same price another company quoted for a central inverter. It's all about efficiency within the installation company and we excel at efficiency.
Also regarding using a 230w module on a 200w inverter, with temperature losses and lack of true 1000w/m^2 irradiance, modules rarely peak over 200w the amount of clipping is insignificant and will only lessen with time.Your single source for sustainable home improvements: [URL="www.eco-merica.com"]www.eco-merica.com[/URL]Comment
185 seems low to me
GTOjohn,
I'm am amateur at this and learned much of my knowledge from reading, reading, reading - only about an estimated 15% of my knowledge currently comes from real world experience including the Harbor Freight kit.
That said..... I couldn't agree with you more that 185 Watts is too small today. I had contractors bid the same to me -- They INSISTED on 180 Watts, and I finally told them to go pound sand.
Almost seems as if they have bought panels 10 months ago and now are trying to sell them to us. They push hard. Tell them to pound sand.
The sweet spot (on pricing) seems anywhere from 200 to 240 Watts depending on brand.
Sorry I didn't answer your actual question, but I wanted to let you know that I support your thought process. Do your own homework and know exactly what you're buying.Comment
GTOjohn,
I once installed a system that could fit more wattage if we used 180s just because of the layout of the roof vents.Your single source for sustainable home improvements: [URL="www.eco-merica.com"]www.eco-merica.com[/URL]Comment
The dimensions of the Suntech 280, as they appear on the product spec sheet are 77 inches by 39.1 inches. Assuming you'll put the 12 panels in two rows of six, and allowing for space in between the panels and at the edges, you'll need an available roof space of roughly 21 feet by 14 feet. As far as pricing, my company offers them for cheaper than what you were quoted, although that's not including shipping and we only sell Suntech panels in pallets of 26. I'd put the link up here, but I don't want to violate any forum rules. I guess just know it's possible to get em cheaper.Comment
NABCEP Russ made an important point that I would like highlight. It is a common misconception that a 280 watt panel is somehow better than a 185 watt panel.
The higher watt panel is not better but is physically bigger.
Similar with efficiency - unless you have space limitations on your available area it makes little difference whether a panel is 13%, 14% or 15% efficient.
What you do care about is cost per watt.
Russ[SIGPIC][/SIGPIC]Comment
Awesome thread.
So, yeah, buyer beware about who makes The Best Panel on Planet Earth. It's system that matters in the end; sizing it to get the tier-shaving and load-shaping that's wanted by the building owner/user. "Best Panel" is advertising. It's catchy. But not useful in and of itself.
That said, so then in terms of strings are we talking NABCEP standards? In terms of inverters - assuming the inverters are sized right - are we talking superior brand?
Is there a manufacturer of inverters that everyone should stay away from ALWAYS? (I heard about Schneider recalling the Xantrex grid-tied inverters last month.)
What does everyone think of Fronius?Greg Kindy, leed apComment
Awesome thread.
I like PVPowered, SMA, & Enphase inverters. Fronius is ok, but not my favorite. I think they're harder to wire than the above brands. I just don't like the feel of the cabinet. Purely opinion. I also don't feel like their enclosure is as robust as SMA & PVPowered.
I've stayed away from Xantrex for the last couple years because of recall issues. The current recall isn't the only trouble I've heard of them having. I figure with SMA and PVPowered, I don't really have a reason to bother with Xantrex.Your single source for sustainable home improvements: [URL="www.eco-merica.com"]www.eco-merica.com[/URL]Comment
Well, I'll leave the NABCEP issue behind.
That's interesting what you say about enclosure. I get that.
Thanks!Greg Kindy, leed apComment
Also to consider, is monitoring options/features. See what's important to you, and how much it costs to get the data. Xanterex GT series have a serial port with data sitting there ready to go..Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
IMHO if you really want to get the most wattage per square foot of space look at the sunpower modules. If you have shading you will have to get permission from Sunpower to use microinverters and they are pricey. I agree with the others that for the most part module output is a function of size. The Sunpower modules have a slightly higher conversion rate than the others.NABCEP certified Technical Sales Professional
