enphase s280 with LG315N1C-G4
One thing hard to quantify that may add to the perception and reality of clipping is the amount of overdesign (or looked at another way, the conservative guarantees or panel rating claims by mfgs.)
If, for example, a panel claims 315 Watts, +5/-0% at S.T.C., it's output might be and probably will be greater than 315 Watts at some time, not only because of some combination of higher irradiance, low incidence angle, low ambient temp. and a breeze, but also because it's efficiency is perhaps and probably a couple % or so higher than the spec sheet says.
Still, the amount of time an LG 315's output will be > 280 Watts and how much in excess of 280 Watts it will actually be will probably result in a small amount of the total annual output being lost due to clipping.Comment
Enphase has to be developing a larger inverter to come out "soon", right? Jrfiero is clipping with 315W panels. My LG 320W panels are sitting at my home, ready for install. What's LG going to have next year? I assume Enphase must have a new inverter in the hopper or they won't be perceived as an innovator.Comment
Enphase has to be developing a larger inverter to come out "soon", right? Jrfiero is clipping with 315W panels. My LG 320W panels are sitting at my home, ready for install. What's LG going to have next year? I assume Enphase must have a new inverter in the hopper or they won't be perceived as an innovator.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
that is my point. enphase is behind the curve on current production levels and is more costly than the competition.
Why pay for premium modules like LG310s and then not harvest all the power?
It would cost LESS on most systems to install SolarEdge than to install enphase (very small systems are the exception).
SolarEdge doesn't have the clipping and is easily able to keep up with new production levels.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
SolarEdge doesn't have the clipping and is easily able to keep up with new production levels.Comment
I just had that exact system installed. 7kW total, 22 LG315N1C-G4 LG panels (315W) and S280 inverters. Enphase says "Commonly used module pairing – input power: 235 W – 365W", really it depends on the max input voltage with is 48V.Comment
Engineer, what a wonderful system! I installed 12 lg 310 with the M250 so I'll be studying your system to see how much power I'm losing by not having the s280's instead.Comment
I installed myself, and received the M250's at a great deal. The cost wasn't a huge concern, but I couldn't justify the 60 dollars extra for each inverter. I'm guessing I average 30 watts of clipping for 3 hours a day which totally stinks. But at the end of the day I'm enjoying the project and even thinking about my next addition. Power bill looks like it will be zero cost which is awesome.Comment
