Hi all. In the very early stages of planning a small solar system. I would like to put a 4kW Micro Inverter Based Grid Tie System on top of the roof of my new garage. Right now the garage has a 100A sub panel wired up with 2-2-2-4, large enough to be fed by a 90A breaker, however, currently it is only being fed by a 60A breaker, back to the house main panel, which is a 100A main panel. My first question is, being 4kW, will a 20A breaker connection at the subpanel be large enough, or too small? And my next question. I am aware of the NEC 120% rule. Being that it is a 100A breaker on a 100A bus bar, would the 60A (or in the future 90A) breaker violate this since it technically exceeds the rating,. even though at the garage it would be protected by a 20A breaker, and therefore no more than 20A would ever be backfed through the sub panel breaker?
Any help is greatly appreciated. If push comes to shove and we have to upgrade the main service to 200A, then it might come to that, but we are really trying to avoid having to take that route if possible.
