"Micro inverters will fail. If you have an array installed into your roof, you will have to climb up onto your roof, remove a bunch of panels just to access the bad inverter, replace the inverter, re-install the panels, and climb down from your roof.
Every time you climb onto your roof and start messing with your panels, you risk damaging something other than the bad inverter. You also risk damage to your roof every time you climb up there. On a ground mounted array, micro inverters are easy to replace. But up on a roof of a home, a string inverter is preferred, IMO."
Ditto... and don't believe the marketing hype known as a 25+ year warranty on roof mounted electronics.
