I have a GE 200A panel. This is capable of using either the "regular" GE breakers, or the "thin" GE breakers. So for a double pole breaker, they come in either 2" wide regular size, or 1" wide thin size. Other than the thickness, there is no functional difference between the 2 sizes AFAIK.
My question is... Knowing that the backfeed breaker has to go at the opposite end of the panel from the main feed (which means at the bottom, in my case), can I use a thin double pole breaker in the spot circled in red (see attached pic) or do I have to use the thicker double pole style and place it in the spot circled in yellow?
The spot circled in red is the lowest usable space for a thin-style double pole breaker in this panel. So if I put the breaker in the red circle, are you allowed to have a single-pole breaker right below it?? Technically, the red space is the bottom-most 240V space, it's just not the absolute bottom space in the panel.
Surely you guys have used these GE panels before... Can I use the spot circled in red for my backfeed, or do I need to hog up 4 spaces and go with the yellow space on the left? Just trying to conserve space in the panel. Thanks for the help.
