Hello guys. I need help here finding the right charge controller or controllers please.
Here is the run down(keep in mind I DO have fuse, fuses, breakers installed in all necessary locations). Ok, I have a 30' Toy Hauler/RV. The RV has (8)eight 250 watt panels on roof(38voc @ 8.75A), I ran #8 THWN-2 straight down to combiner box(parallel)...[ "Insert CC here" ]....Ok, so after CC will be charging 12 volt battery bank(1,200 a.h.), then Xantrex 2000watt inverter. And before we get on the subject, yes, I know this is alot of output amperage. I know I could go up in voltage to drop inversely proportioned amperage down but I need this system to be 12 volt....because the RV lighting, pumps, etc are already 12 volt, appliance are 12 volt, etc.
So here's the big question= do I use one big CC like Midnight classic 150, or do I split it up and use two CC together on one battery bank like the Xantrex mppt60-150 ? ...Or will either of these even work the way I'm seeing it? ...I'm exhausted, my brain is fried, help please.
