Maximizing the efficiency and longevity of the inverter seem to be worthwhile goals. Running an inverter below capacity may prolong the lifespan of the inverter. But the question is how does this affect efficiency. Conventional wisdom seems to be that the efficiency is maximized near the rated capacity. Looking at the actual efficiency curves, however, efficiency actually goes up as load goes down for some inverters, with a peak efficiency at some point in the middle of the range. For the SolarEdge 3-phase inverters, the peak efficiency seems to be at approximately 50% of rated capacity. For some SunnyBoy inverters, the peak efficiency seems to be even lower. For example, see this efficiency curve for the SunnyBoy 10000TL-US, where the peak efficiency seems to be at approximately 25% of capacity:
I am not able to find the efficiency curves for the SolarEdge single phase inverters, however. For example, the SE10000A-US or SE7600A-US.
Does anyone know where to find the efficiency curves for the SolarEdge single phase inverters? Alternatively, do you happen to know the load at which peak efficiency is reached?
