Guys, I am drawing my first permit for 8 panels in one string of 2616W total DC Power. On DC side I will use #10 Cu AWG ”USE-2” wire with #6 Cu AWG bare ground to go from the panels to the inverter. I only have a roll on white #10 AWG USE-2 wire. Can use white “USE-2” wire for both positive and negative, or do I need to get different color, or somehow label the wires?
My transformerless string Inverter SMA 3000TL-US will be inside the garage, and it has maximum output current of 15A at 240VAC. Romex 10/2 is good for 30A. My question is if there will be problem with me using Romex 10/2 to connect inverter to AC disconnect that sits on the outside wall of the garage? The Romex 10/2 will be inside garage only.
Since I am using a transformerless inverter, I do not need to ground the inverter using grounding electrode. However, if I use Romex 10/2 in the garage, that means I will have ground conductor mismatch on the DC and AC side - #6 CU AWG bare ground on DC side, and #10 AWG ground that is inside Romex 10/2 on AC side, even though my inverter in transformeless. Is that against the code?
Another question is if I am allowed to use generic Air Conditioner AC disconnect available at Home Depot that costs $13 - AC Disconnect 30 Amp 2-Pole Fusible NEMA 3R
http://www.homedepot.com/p/GE-30-Amp...specifications
It is “Type Air Conditioner “. Is there any difference between Solar AC disconnect and Air Conditioner AC disconnect?
Thanks,
Tomas
Thanks,
Tomas
