Is there or will there ever be a 48VDC outlet standard for homes & buildings?
+ More Options
Posts
  • ZoNiE
    • 129
    I realize the discussion is moot. Would be nice. Yes Breakers (and wire insulation) are usually rated for the max voltage present, usually 300V, sometimes 600V. I think we would end up with one voltage, not 120/240 (like on the range, Dryer, etc.) and there are many ways to do this. Yes some rejiggering of the panel would be necessary, and the end result would be one leg and neutral, 240 et al to Neutral. Probably tie the bussbars in the panel to one leg from a transformer, and the other leg becomes neutral on the load side. Replace 2 pole breakers with single pole breakers on those circuits and tie L2 to Neutral.
    Would definitely create jobs, but would be about as impossible as converting the UK, It's former colonies, and Japan to driving on the Right.
    Being first also gave us the lovely 525 line NTSC Television... But then PAL and SECAM sucked, But that is a whole 'nother debate. What we have now with side band channels (3.1, 3.2, etc) and varying resolution and picture format sucks ass. I miss the old analog days where changing the channel gave you an instant picture.
    House-Sun Earth Hot Water.
    RV-390W Kyocera, Kid.
      Perhaps I misunderstand what you are saying? The voltage architecture does not change. L1 to L2 = 240 L1 to G = 120, and L2-G = 120. There is no grounded circuit conductor, except from the utility and it terminates to Ground in your main panel just like it does today. All receipts and hard wired appliances are 3 wire L1, L2, and G. No current flows on G, it is there just for safety.
      Lastly you can still have 120 circuits if need be. Nothing has changed that would prevent you from doing so.
      • ZoNiE
        • 129
        I'm not stating it properly.
        L1 and L2 go to primary on a 1:1 transformer. Secondary are still 240, but one side is tied to GND, so effectively becomes neutral. Whammo, 240V L-N.
          Nope you stated it properly to me because I though that is what you meant and why I questioned it. There would be no neutral or grounded circuit conductor, just 2 hot conductors plus equipment ground, no neutral, just L1, L2, and G
            A technical point:
            The "netural" conductor is properly one which has equal voltage to each of the other conductors used in a circuit. It may or may not be grounded.
            In the case ZoNIE describes, there would be one 240V hot conductor and one grounded conductor, with no neutral since the opposite polarity 240V is not part of the scheme.
            ZoNIE and Sunking are still talking about two different situations, I believe.
            Sunking is describing how to use 240V loads on an existing 120/240 wiring system, and it requires adding an additional conductor to an existing 120V circuit in order to get 240V OR disconnecting the white wire from the neutral bus and connecting it to the opposite hot wire, giving a balanced 240V feed.
            Other than the small matters of having to change the connectors and the NEC's unhappiness with using a white wire for an ungrounded conductor, that would work.
            ZoNIE appears to be talking about producing either a single ended system with 240V to ground (and no neutral, although there is a grounded conductor) or a balanced system in which both hots were 240V to ground and the grounded wire would still be a neutral.
            • warinwarin
              • Oct 2014
              • 3
              i lie zonie's comment and support it
              -ModNote: No unrelated links in signatures please.
                Dave 240 AC in your home is balanced by the center tap of the secondary transformer being grounded. 120 in your home is unbalanced and the crux of many electrical interference problems encountered like HUM in your AV equipment.
                Recording studios use balanced 120/60 systems with great success, and NEC has a Article dedicated to Balanced 120/60 volt systems in article 647 titled Sensitive Electronic Equipment. Back in late 1990's while working for MCI-Worldcom we used some of it in data centers to eliminate noise and bit errors that use unbalanced (grounded) signal transmission protocols like RS-232. Today with optical isolation and balanced signal protocols put an end to it. Th eUSA would be in much better shape if we had used 240 instead of 120. That is the consequence of being first to electrify. Dang Edison and his light bulb.
                • ChrisOlson
                  • Sep 2013
                  • 630
                  The 230V single phase system is much more efficient than the US split-phase 120/240V system. However, some things can be switched to US split-phase with very little effort. My wife bought a Swedish-made 230V Electrolux range with induction cooktop in Sweden and had it exported to the US. Electrolux simply changed the power transformer in it for split-phase, switched two wires around in it for the digital clock, and changed the cord to the US-style standard three-wire 240V plug. It works fine on our split-phase off-grid system and the clock on it keeps perfect time.
                  off-grid in Northern Wisconsin for 14 years
                  • ChrisOlson
                    • Sep 2013
                    • 630
                    Originally posted by tonypsofla
                    The 20% energy loss of transferring 48v battery to AC and the electronic products change it back to dc is just a waste.
                    I don't know about electronic stuff. But there's not that much loss in converting 48VDC battery to AC with a good quality inverter. I have measured our inverter at 97% efficient in the DC to AC conversion at 20% rated continuous load, which is where it runs most of the time in our house. I have a friend that lives in Alaska that has the same inverter we got, and much better measuring equipment. He measured his at 97% efficient at 1,200 watt load too.
                    So to put that in real-life terms, the average loss in converting DC to AC for a typical off-grid home that uses 16 kWh/day is only 480 watt-hours. I believe that if you factor in the I^2R loss of using low-voltage DC, and the extra cost of wiring and switches in the house that can handle the DC arcing, there would be no gains in using 48VDC power directly. And probably considerably more loss with heavy draw things that pull say 4 kW where you'd have to have wiring, switches and plugs capable of handling over 80 amps.
                    The other thing is that electronic stuff, as far as I know, runs at all kinds of different internal DC voltages. So instead of using transformer and rectifier of some sort you'd have to use DC->DC converters to change your 48VDC to the proper voltage your electronic thing requires. I doubt there'd be any gains there either.
                      Why the cheap SOB's in Sweden. I meant that humorously. However I must have missed something. If the cook top worked on 230 volts, why would you need to change anything?
                      But I had a reason to say it. Most major appliances (high power requiring 240) desktop computers, high end AV equipment and some other things that have slipped my mind are designed to operate in the 190 to 275 volt range. That gives them international market capability. Some of the things like Ovens or things with motors have a multi-tap transformer built in. The electrician simply terminates to the right transformer tap.
                      And for everyone information the USA did change voltage standards by raising the single phase voltage standard. In the beginning it was just 110 volts followed by 220/110.. That was directly related to Edisons light bulb requiring 110 volts. Well technology has advanced and today the standard is 250/125.
                      Now for the rest of the story.
                      • ChrisOlson
                        • Sep 2013
                        • 630
                        Because of the difference in grounding. The European 230V neutral is the same as ground just like 120V US single phase. So if the neutral connection to ground is lost everything tied to the neutral is hot. In the US the 240V split-phase uses two "floating" lines that are totally separate from ground. That needs to be changed before you can use a European appliance on US 240V split-phase power because you are essentially plugging it in to a system where what is their neutral is now a hot wire with no connection to ground. Electrolux told my wife they could not export the range to the US without changing it.
