How to connect Solar Street Light with Charge Controller, Battery and Solar Panel
  • mbm2014
    I am newbie here.
    I am doing solar installation of any sort for the first time at home.
    I am installing solar street light at home that lights at night.
    I have following connection,
    Solar Panel (35wp) --> Charge Controller (12v 10amp)
    Charge controller (12v 10amp)--> battery (12v 35amp)
    I have 2 connection/terminals on solar LED Light 1) battery 2) solar panel
    Question: not sure how to connect solar LED light (9W) to battery and solar Panel?
    Any help here is much appreciated
    Thanks
    Well if you have a 9 watt LED to light up I hope it is not turned on more than 5 or 6 hours each night because a 35 watt panel with a PWM controller cannot generate more than that.
    If you are thinking more like 12 hours each night you are looking at a 75 to 100 watt panel with a 12 volt 60 AH battery.
      • 15160
      Originally posted by mbm2014
      I am newbie here.
      Thanks
      The two wires from the solar panel connects to the charge controller terminals. The charge controller connects to the battery. Depending on the type of charge controller you have you may be able to connect the LED light to the "load" terminals. Some cheap charge controllers may not have "load" terminals or do not have the capability to power high wattage loads. That 9 watt light may be ok.
      Also as Sunking mentioned you will not be able to use that 9watt LED all night running off that 35Ah battery because your 35watt panel is a little small to recharge the battery back in one day. You will eventually drain your battery too low. Better to go with a larger panel at about 70 watts minimum.
