Hi all,
I originally sized my battery bank and system to be able to provide power to charge cell phones, laptops, tablets, etc. So it's not a huge system. The panel is 100W, 12V, the battery is 12V 34Ah. There is a Sunsaver charge contoller in between and 400W inverter connected to the battery. It's all set up and working, so that's great.
Now, I'm trying to figure out if there are any electronics that I can have permanently attached to the system in addition to the random cell phone or tablet charge. It seems that I've got excess capacity based on my calculations, so I want to make sure I've got a good idea what I could reasonably do. Last thing I want is to kill my battery by inadvertently discharging it too much. To that end, I've done a few calculations that I was hoping folks could poke holes in. My discharge calculations are below, but here is my theory.
With the panel connected, it's going to generate 5.29 amps (at full sunlight). I'm shooting to constantly power a 1A modem at all times, plus random phones tablets, etc. For the sake of this example, let's say my average draw is 1.5A for 24 hours a day. In full sunlight, the <b>battery will be charged because 5.29 > 1.5</b>. Let's assume that the battery gets to a full charge by sunset, using my table below, if I'm drawing 1.5A on average, then I'd have a little less than 12 hours before the battery is discharged to 50%. If I unplugged <b>all but the 1A modem overnight, then I'd have closer to 20 hours before 50%</b>. I believe I'm understanding the amp hour ratings appropriately.
Second piece of this is, if the battery were to be fully discharged to 50.1% overnight (so it never actually shuts off) and then the sun rose just before it got to 50% and started charging, <b>my charging time would be 17 AH / 5.29 = 3.21 hrs to get back to full charge</b>. This assumes that I have no load on during that time. It would be 17 AH/(5.29-1) = 3.96 hours if there was a 1 amp draw during this time.
I want to make sure I'm not misinterpreting anything here before I start to test this out. The charge controller has indicators that glow yellow when I get to 50%, but would prefer to know that I'll never get there. Hope this makes sense. Thanks for the thoughts.
Battery Discharging: 34 Ah battery (24 hr rate)
| Amp Hours | Hour Rating | Calculated Amp Draw | Watt Hours | Available hours (discharged to 50%) |
| 28 | 4 | 7 | 336 | 2 |
| 30 | 8 | 3.75 | 360 | 4 |
| 34 | 24 | 1.42 | 408 | 12 |
| 36 | 48 | .75 | 432 | 24 |
