Sure it does. First look at the IR curves published for solar panels. The portion you want to pay attention too is the vertical line that runs from MPPT Knee down to Zero Volts at Zero Ohms. The current is almost linear. For your panel I am guessing at MPPT voltage the Imp current is 2.9 amps, and at Zero Volts or Isc is 3.1 amps. So what is the Power? It is undefined as it depends on what resistance you are pushing the current through. The highest current possible assuming 100% irradiance input is 2.9 amps so the power is 50 watts @ Vmp of 17 volts.
But what happens if say we take a 6 volt battery and connect it to the panel. Imp has not changed as it is still 2.9 amps. But we pulled down the voltage from 17 volts to 6 volts. What is the power now? Could it be 17.4 watts?
What if there is haze in the area, or the panel is not facing directly into the sun so the irradiance has dropped to 50% input. Well since a panel is a current source and the output current is directly proportional to light input our current falls off to 50% or 1.45 amps. Vmp does not change and is still 17 volts, but now Pmax is 25 watts.
So answer some simple Ohm's Law equations using a constant current source. What is the voltage and power with 2.9 amps throwing through
0 Ohm
1 Ohm
2 Ohms
3 Ohms
4 Ohms
5 Ohms
5.94 Ohms
Now here is where magic happens with a solar panel When you go above MPP voltage, the panel now turns into a voltage source up to 22 volts at Open Circuit infinite ohms. So when at 21 volts what is the power and current at 20 ohms?
Run through those equations may shine some light in a place you have never seen before.
0 Ohm
1 Ohm
2 Ohms
3 Ohms
4 Ohms
5 Ohms
5.94 Ohms
