So, I am new to solar power (and this forum) and wanted to get started with solar in a small way with experiments just for the fun of it and to learn as much as I could (and to have a minor backup if the power went out). I've recently become fascinated with generating my own power. I'm also living overseas temporarily and don't necessarily want to travel with tons of solar panels in my baggage! So I mail-ordered a couple of 50 watt mono-crystalline panels, a good charger/regulator, a sinus wave inverter and I bought a few deep-cycle batteries. I bought two 12v panels so I could make either a 12 or 24 volt system. I also bought a 130 amp DC in-line wattmeter for measurements, besides my regular multi-meters.
I wired it all up and noticed I was only getting about 35 watts per panel. I wrote the supplier and complained. Of course I got the mantra about clear sky, facing sun, humidity, temperature, wire size, etc. I assured them that I understood all that and it was all optimized. Then they mentioned an MPPT charger, which I was not familiar with, and upon reading up on that, I ordered one (which hasn't arrived yet) but it made sense about the voltage limitation of the battery and the charger. So I did an experiment with a ni-cad battery pack. It was a 12-cell pack which can easily go up to over 20 volts while charging and will accept a pretty hefty amperage. I wired it directly to the panel (for a short time). Guess what? Still 35 watts.
So I wrote them and told them this. They said measure the voltage and amperage without a battery or charger. I replied that you can't have amperage without a load (meaning a closed circuit) and assured them that I knew a bit about electricity. They assured me that they did too and sent me a video showing them measuring the no-load voltage of the panel, and then changing the meter to amperage and checking the short-circuit amperage. Of course, when I did this, I got about 20 volts and then 2.5 amps. Voila' - 50 watts! But I explained to them that this is an invalid measurement, since they are two separate measurements under two different conditions. I then made my own video using two meters, to show that when you short-circuit the panel, the actual voltage drops to just over one volt.
They then contradicted themselves by saying the panel wattage is figured with the maximum voltage (18 volts) and the maximum amperage (2.78) but that you will never get the maximums (what?!). Of course, both those are under load, since it also lists the open circuit voltage (22.18) and the short-circuit amps (3.34). So even though I clearly made my argument correctly, their ultimate answer was "you'll never get maximum." I could understand if it was 48 watts, or even 45, but 35? That's fraud in my book.
Here are the specs on the panel.
My ultimate question is: is this industry standard? Are all panels grossly over-rated so that "you never get maximum"?
