I'm new to solar tech and have many questions. My objective is to reduce at least $100-150/month to the utility company. I'm using power to power Macs and PCs workstations. A 16-core Mac Pro with 4 filled eSATA hd bays will consume about 180-250 w. It depends on how much processing is used. Leaving it idling is about 180w.
Here're what I'm planning to get for a starting system to test the water:
Grape Solar GS-S-250-Fab5 250-Watt Monocrystalline Solar Panel
Vmaxtanks Vmaxslr125 AGM Deep Cycle 12v 125ah SLA rechargeable Battery
Voltec 10-00487 Pure Sine Power Inverter, 2000-Watt, Blue & Black
So my preliminary setup is as follow:
125 AH AGM -> Pure Sine Wave inverter -> Tripp Lite 2200 VA UPS -> Mac Pro, 27" LED monitor, speakers. ext hdds.
I'm estimating about 350-400 w of power draw for a short 10-12 hrs per day period. I will not be using it every day.
More like every other day. This should allows plenty of time for the panel to charge the battery on the off days
I'm still baffled is to find a 24 vdc charge controller that will charge 12 VDC panels. There are 180w 12 VDC panels, but because of
tight space, I prefer to have large wattage panels (3 max) vs. smaller ones. Is it possible to get a 12/24 VDC charge controller to put the voltage
down to 12 vdc? Is it safe during sunny day to simultaneously use the 250 w panels while also with the battery?
Future expansion will be two 250-w panels and two 125 AH SLA batteries in parallel to boost the wattage. Not planning to do any switch over to the house.
This will be installed in a 15x20' shed with its own independent off-grid power supply.
The initial investment of about $1,800 should pay itself after about 15 months of use. I do no want to exceed $3K for solar equipment to make this work. The electric bill adds up quickly for these computers. Kind of wasteful. My concern here is that I'm not sure if the SLA battery can handle continuous demands for about 500 w of power. Planning to use the computers from 9am to 9 pm.
Roughly a 12-hr continuos power period only.
