I am working on a problem that is causing a 1.12 Mwatt PV system to shutdown. There are two 500 Kw inverters supplying 480 volt power to a High School in Nevada. There have been recorded events that show sometimes one and sometimes both of the inverters shutting down due to a fault listed as "frequency shift".
From what I have been able to determine this fault is part of the anti islanding protection to take an inverter off line when it detects an abnormality on the grid it is connected to so it doesn't back-feed a grid that is powered down. While this type of control is normal for a grid tie inverter it seems that an event lasting maybe 4 to 10 cycles seems pretty short to take the action of a complete shutdown. The safety of Utility personnel is important but an event that lasts less than a second and then is gone but still shuts down an inverter seems to be an over reaction.
My question to anyone that is familiar with this type of fault. Exactly what event is happening on the Utility power grid to generate a "frequency shift" and do other inverters shut down almost instantaneously for this type of event?
Vince
Vince
