A long-time stroller, signed up today for my first post
Inspired by the forum members, made my first step towards solar electrification of my house today
The installers had put the panels up earlier in the week, but came with the epSolar MPPT charge controllers today and finished the wiring. This is what they look like:
My concern with the above is, is it OK for the wires coming in from the panels to go straight into one, and then to the second charge controller from there? Although they are identical charge controllers, will they get equal voltage in?
Presently setup 800w of panels, we have two inverters (one for each floor) with seperate batteries hence the installer suggested to get seperate charge controllers. If this thing works, the idea is to increase the panels (hopefully double the present).
I hope this setup will work?
) to the first CC, and the same amount was going to the second CC; the second CC was sending 13/14 v/a to the battery bank (again, not sure what the numbers meant just that the MPPT CC was sending out more than it was receiving). The first battery bank (with higher load) had consumption of 25amps and getting charged in 22/23amps, and its voltage was now at 24v instead of the previous 29v at full charge. The second battery bank (with negligible load) was only drawing 0.5amps, and was showing voltage of 24v. (I'm sure I've messed up alot of the units here but I'm sure you guys get it
