Self consumption Sizing
  • Bendesa1962
    • Nov 2016
    • 110
    Hi All,
    Just curious about your opinions.
    How do you design / size the maximum capacity of a PV System that you want to be self-consuming. (No export to the grid)
    So it's a grid tied PV System. No storage equipment. Just verry simple Grid Tied.
    Let's assume there is an average evenly distributed consumption (load) during the daylight hours of 150.000 Watt
    How would you calculate / size the system ?
    Many thx in advance for your contribution
    Kind regards
    B
  • Mike 134
    • Jan 2022
    • 430
    06-16-2022, 09:05 AM
    Hi Suneagle
    thx for your replay. This projects is just South of the E. I ask this question because there seemed to be different opinions on this.
    And you're right it's not for a residential installation. It's an industrial project of total 1 MW.
    Thx for your contribution.
    How did this project workout for you?
      • 15005
      Hi Suneagle
      Is this post in the right thread ?
        • 15153
        Hi Suneagle
        Is that question directed to me or to Bendesa1962?
        • Mike 134
          • Jan 2022
          • 430
          Bendesa
          • Bendesa1962
            • Nov 2016
            • 110
            Hi Suneagle
            Hi Suneagle,
            I guess this question is about the different orientations of different strings on 1 MPPT right?
            Well the project is still in the phase of designing and there are some different opinions about this topic.
            Personally I think the difference between those two options are negligible because it's located so close to the equator.
            The tilt of the roofs is only 15 degrees,
            So I think it's not necessary to use two different orientations on 1 MPPT.
            Kind regards
            B
            PS What are your thoughts on the self consumption question?
              • 15153
              Originally posted by Bendesa1962
              Hi Suneagle,
              Kind regards
              B
              If the array is on or close to the E then it really doesn't matter which way they are pointed. The wiring to the inverter will depend on the maximum allowed input so IMO if the inverter has more then one inputs then splitting the number of panels and wiring half to each input makes sense to me.
              As for the self consumption question. That will depend on what your loads are and when they are being used. I believe some grid tie inverters can be programmed so as not to sell back any excess power that is not consumed by the loads. But that is something you need to engineer into the design.
                If you aim for zero grid export in the the winter, you will be overpaneled come summer. But maybe you will kick on the big air conditioners then. There are
                many details to factor:
                Times of power usage
                Usable solar hours / obstructions winter/summer
                Is there a cost goal ?
                does your utility not allow grid export, or are you trying to sneak in under the radar ?
                Backup solar or generator power if grid is down ?
                • Bendesa1962
                  • Nov 2016
                  • 110
                  Ok let's open up and give you more information.
                  The project is realized under BOT Built Operate Transfer. With a zero investment for the client.
                  The PV System will be installed on the factory roof of the client.
                  An Investor will finance the whole system
                  The client buys the produced kWh by the PV System against a tariff of minus 10% of the utility company
                  The investor operates and maintains the system for a period of 20 years
                  After 20 years the system is transferred to the client.
                  The country is Indonesia
                  All kWh that are exported to the grid will not be payable for the investor so no revenue
                  The Utility company does not give any credit for the exported kwh
                  So I'm looking for the balance between maximum capacity PV System and maximum savings for the client and maximum
                  revenue for the investor.
                  How would you determine the maximum PV System Capacity?
                  And yes I know many variables are involved and that the numbers are not static
                  I'm just curious what are your thoughts on this
                  Many thanks in advance
                  Kind regards
                  B
