I am in the process of doing a solar installation.
The system consists of two ground-mounted arrays. The North array has 10 Heliene 460 watt panels. The south array has 11. Each array will be connected to an SMA Sunny Boy 5.0-US-41 inverter. The input for these units allows for 3 strings of up to 10amp modules. The Heliene 450 watt modules are 10.8 amps so I will make each array a single string and connect them to the SMA as string A with a parallel jumper to string B to avoid the out-of-spec amperage. As far as I can tell, SMA seems to suggest that work-around.
There are a few more pieces to this project so before I connect this to the grid or my home electrical system, I want to do a lot of testing. The problem is that the SMA manual says that I need to enter an SMA Grid Guard number within 10 hours of first firing it up. It is my understanding that Grid Guard is SMAs way to comply with the electric company interconnect tariff Rule 21.
I don't want my Sunny Boy inverters to turn into unusable potatoes. So, can anyone tell me the full story on SMA Grid Guard?
 SMA Grid Guard
									SMA Grid Guard
