Hello alls
So my wife and I are strongly considering purchasing an outdoor gasification boiler to heat our home, my shop, and our domestic hot water... reducing our electrical usage during the lower power production part of the year.
I was outside yesterday and staring at my array on the roof of my shop which is currently covered in 6" of snow and 1/2" of ice under that. I dread this time of year.. its either climb up on the ladder in the ice and snow to clean the panels off... or live with the lack of production for a week or more at a time.
We have a ~10kw array on the roof of my 24x48 pole barn. Metal roof with IronRidge racking but fairly low pitch (4/12).
Then a thought popped into my head. Many use their outdoor boilers for in floor radiant heat using pex tubing. Could one run a loop of pex (valved for isolation) between the array and the metal roof? Block off the top and sides to hold in heat and only open the valves on the loop when snow or ice is forecast. I think it would provide enough heat to keep the panels above freezing melting any ice or snow that landed on them but not hot enough to cause issues.
Wouldn't take much in materials as there will already be a heat exchanger in the shop. Would take a bit of work fishing the pex under the array without pulling panels but I think it's doable. Obviously the boiler would be burning through a good bit of wood while that loop is active so there is that to consider.
I'm not aware of any regulation or code that would prevent such an installation.
Thoughts? Would it work?
The boiler will likely be filled with a glycol mix so freezing wont be an issue.
