DIY Combiner Box
  • jasonl549
    • Nov 2012
    • 19
    DIY Combiner Box
    Just thought this might be helpful to some of the newer folks on the forum. If you have the money, by all means buy a Midnite Solar or other name brand combiner box. But for those of us on tight budgets, here is another option:
  • solarix
    • 1415
    As you stated the QO breakers are rated at 48Vdc so is not suitable for most off grid arrays feeding any modern charge controller that goes up to 150Vdc (or more). It is such an advantage to get the string voltage up as high as the charge controller will allow, that hamstringing your array with a 48Vdc combiner doesn't make sense to me. Going with 200Vdc+ strings for a Midnite Classic200 for example allows you to run as many as 6 panels in a string and up to twelve panels before even needing a combiner.
    • jasonl549
      • Nov 2012
      • 19
      @solarix That is true, good point. I probably should have emphasized that more in the video.
      But the majority of off grid solar applications do not go above 48V. I guess I should have posted this in a different sub-forum because you are right, homeowners off the grid will be using higher voltage to power an entire home with long cable runs. This DIY build is for everyone else that is using them for RV's, boats, sheds, workshops, job sites, SCADA, surveillance cameras, and other smaller off grid installations.
        Once someone is using over a 1kw inverter, stepping up to the next voltage (24v) makes more sense then bunches of parallel batteries and super heavy fat cables
        • littleharbor
          • Jan 2016
          • 1998
          I like the video. Have built many of my own combiner boxes. All I would add is that the Midnite or Outback dc breakers are very competitively priced, making the need to use QO or QOU breakers with their relatively low dc rating unnecessary. You may need to use din rails in the enclosure though.
            Also, sometimes DC breakers have a "polarity" of which direction the current flow goes, and their internal arc suppression works best in, You may see a + on one of the terminals.
              • 5209
              I am wondering if you actually plan to physically open a conducting breaker? That
              is something to only be done in an emergency for my 400VDC grid tie system. If
              not, DIN mounted fuse holders can be used, and can be used to break the circuit
              manually when the sun is down as well.
              The Evil Bay fuse holders I ordered were economical, and I asked them to put in
              the proper size fuse, no extra charge. Bruce Roe
              • Takis
                • Oct 2019
                • 64
                As soon as the panels have build in blocking diode and they are fused and grounded appropriately, what else is nessacery for safe use?
                  Most panels, do NOT have a blocking diode, that task is usually handled by modern Charge Controllers.
                  Many panels contain several BYPASS diodes, that allow a partially shaded panel to pass electricity thru it, instead of totally stopping the electricity
