So, after messing around too much trying to get present under-powered system to function reliably, I decided to add 3 270w panels that I had lying around. I also have an Epever 3210 on hand. Problem is they're not compatible. Epever has an input limit of 100v and open circuit for panels - in series - is 115v.
I'd really like to use what I have on hand, so, question 1: If I parallel the 3 panels would 31v be enough to drive Epever for 24v bank? (I don't think so)
Question 2: If not, is the solution to buy a PWN instead? Or... anyone know of a cheap MPPT that works at 125vdc?
No shading or wiring issues, the latter is already established. My goal is to add an extra 20~ amps to system, a 30% increase.
Thanks
Thanks
