I've been researching solar pergolas as much as possible, and there are quite a few examples online. The concept at a basic level seems pretty simple and very intriguing, and even has some side benefits (like being able to count the cost of the pergola itself for tax credit purposes since it's effectively serving as the racking for a ground-mount solar array).
The one thing I don't feel like I've fully figured out yet though is how people design for rain. Many of the pictures I've seen would seem to obviously imply a structure that's meant to have no water leaking through the top (though it's an outdoor structure, so it's not at the same critical level as it would be on a home roof, for example). Several companies doing custom design even explicitly call out the "roof" being weatherproof.
The basic overall idea is using bifacial solar panels on top of a "trellis style" (for lack of a better term; i.e., not something with a traditional roof) wooden pergola structure that would serve dual purpose as both solar generation as well as some shade protection (though the bifacial panels let in some light) and also some cover from precipitation.
I suppose the solution might be different between standard framed and frameless panels, and I've been contemplating anything ranging from:
Does anyone have any ideas on what might work or experience on this kind of project?
- Using some kind of channel system to act as a "gutter" underneath each panel intersection, to
- Using a UV rated weatherproofing tape to bridge from the panel to the structure, to
- Using roof-grade rubber to act as a buffer between the panel (either on the side or on the bottom) and the structure, and rely on the clamping to create a seal with that rubber.
