Hello,
I am brand new to the forum and the solar world, so apologies that my question has probably been covered many times before...
My question is regarding series connection of solar panels, which I believe I have the answer...I just need reassurance from the experts
Our setup is as follows (I have only erected the solar panels, so we are at the beginning with loads more work to follow). We live in Southern Europe with over 300 days sunshine.
16 x Tenesol 210w solar panels
29.7v vmp
7.10a imp
36.20v voc
10a max service fuse rate
Hybrid 5000w inverter 48v
MPPT 80a charging current
145vdc (max PV array open circuit voltage)
64-130vdc (PV Array MPPT voltage range)
34vdc (min battery voltage for PV charge)
BYD 5000w Lithium battery box
Genergy Guardian S6-Sol 6000w generator backup for very bad weather.
I suspect we should have 4 x solar panels in series? 4 x 29.7v = 118.8v @ 7.10a?
But do I simply connect each of the 4 x positive and 4 x negative series connections into one with a joining connector, then to a circuit breaker before the inverter?
Or do you guys have a better suggestion?
Also, do I use the standard solar cabling for the PV series cables to the inverter or worth investing in AWG 6? Considering the low amperage standard solar cables should be ok?
Some information from the inverter manual is attached below.
Thanks in advance!
Regards
Rob
29.7v vmp
7.10a imp
36.20v voc
Thanks in advance!
Regards
Rob
