Well said, Butch. FWIW, if you are not comfortable working with voltages over 240, then don't play with large arrarys.
pv system connected to sub-panel
you are the king of not paying attention (context). you & a couple more have hijacked this thread and made it about you. it's not about you. and the veteran members and moderators have stopped posting here after you hijacked it. do you do this to everyone?
Ok yes you are the king of random statements. You claimed that the advantage is that the can have less loss due to D.C. Runs. I corrected your inaccurate statement that it is not the D.C. But the high voltage that makes it have less lose.
it doesn't matter if you already told someone or are arrfrade of D.C., facts are factsComment
We have given up on the OP who can't seem to accept answers given already.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Just take that "someones" suggestions and file them in the round file. Sure, if you cut corners, skimp on safe gear, use AC rated instead of DC listed gear, you will have a problem. Just use the right tools for the job, But if you can't do that, or won't, you are stuck. I can give you sound technical advice, but apparently "someone" knows a hell of a lot more than me.and i already told someone that suggested this that i am not interested in long dc runs. too dangerous. more context added.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
As Butch states it doesn't matter if the voltage is AC or DC once you get above 50 it becomes dangerous.
I have seen the result of someone having contact with 115V AC and know that they could have been killed but got lucky. I have also seen what a 480volt AC arc flash do to equipment and people. That type of flash can result in body parts being burnt to a crisp.
AC is not safer than DC. People who come in contact with either can be killed if they are not careful.
as of last week the system passed inspection. the new net metering meter will be installed after the holiday!Comment
the 3kw system is now operational after the power company installed the net metering meter.
thanks to all for the help.Comment
i finished the final portion of the system per FPL guidelines in August 2018 and everything has been operating nicely with no problems!Comment
