Has anybody actually seen that done? The equipment is here, but unused. I would be concerned that the buck
trans might raise the apparent line impedance enough that it refuses to run. Bruce Roe
pv system connected to sub-panel
i have already bought the micro-inverters and the cabling.Leave a comment:
Still if it was up to me I would go with a string inverter because it would be cheaper and reduce the number of failure points.Leave a comment:
this sounds like a patch. i might even scrap the micro-inverter approach and go with a string before finishing this first effort.Leave a comment:
But if you are only concerned with operating stability and not with lost power in the wire resistance, you can use a buck transformer configuration to reduce the apparent grid voltage at the micros.Leave a comment:
part of the problem most face with implementing a pilot system is due to revision. so many projects are NEVER implemented due to revision. they want a perfect pilot. dumb. the pilot is built as a basis for evaluation. i expect the system to perform well since it has for others. i learned today that virtual net metering is NOT offered by FPL and might NOT ever be offered (at least until customers scream for it). i learned this month that the micro-inverters might have difficulty providing electricity to the grid. so presently i am considering implementing a string inverter system next year. flexibility is the key.Leave a comment:
The MEP-802a TQG has been released for some time now. Much quieter. You might be able to find an Acoustic Suppression Kit (ASK) yours. The technical manuals, parts manuals and such can be found at
steelsoldiers.com
great bunch of guys there too, for information and troubleshooting help
I have a mep-831a variable speed inverter. .2 gal/h love it.
planning on using a Schneider SW set up to load shave for starting heavier loads.Leave a comment:
I don't understand your plan at all. Is your permit and interconnect agreement with your utility for 3 kW? Are you intending to pull another permit and revise the interconnect agreement for the expansions you are talking about?Leave a comment:
I see that the diesel generator will output 120v single phase 2 wire, 120/240 single phase 3 wire, as well as 120/208v 3 phase 4 wire. Interesting design but it does provide power for a multitude of different voltage loads.Leave a comment:
