OK - but that doesn't answer the question I asked.
Is the POCO going to run the wires (and conduit) for the new service?
And can YOU (well, your contractor) do the conduit and wires?
(It *may* be cheaper for you to hire someone to move the dirt, and an electrician to do the conduit and wires)
Electricians usually don't like to shovel dirt, so they often charge more for it than you'd pay hiring someone yourself.
This IS a chance for you to upgrade your service and get a 30% break on it's cost.
If I had a choice between a house with 100A service and one with 200A service, I'd take the 200A service assuming other things were equal.
(I had 125A and I upgraded to 200A - I no longer notice lights dimming when the AC kicks in.)
You mean a system with a 20A breaker. (3.8kW)
Depends on how much it costs and how much you use.
If it's $3/W or less, probably still cost effective.
(probably MORE cost effective than something that'd be near 100% kwh replacement)
It's also quite possible you could do 4.5kW or more of DC panels with only 3.8kW inverter and get over 90%+ of the production as if you had an inverter that could handle the full peak.
If you mean the fed credit, it isn't "one time"
Read IRS form 5695 instructions to confirm for yourself.
I'd start with "Where do you want me to put the meter? I see from your rules it's not supposed to go inside a fence. It's currently on my home office's exterior wall, why can't it stay there?"
(And don't have a bed clearly visible through the window next to the meter)
It is not code.
It's a rule from your POCO.
So I am stuck with a 100 amp solar system which won't offset my usage that much
A solar system that weak won't be worth it or cost effective?
waste my one time 30% credit allowance?
As Sunnyguy suggested another questionable option would be to close/wall off the closet thus making the bed room into a non bedroom?
If I'm reading the code right myself and thousands of others with main panels mounted on bedroom walls are already illegal which is ridiculous!
